ecu help needed
ecu help needed
i'm changing the head of my sohc d15b8 motor which is a 8 valve with a d15b7 16 valve head do i need to change the ecu or can i run with the same ecu
if i need to change which one should i use
thankz guyz
thankz guyz
Re: ecu help needed (dee16z6)
you might need to change ECUs. not to sure though. u can try the ECU that u have, if it runs like crap then u know it might be your ECU. i would get a P28 if anything.
easiest way is to chip it, and run P06 maps on the ecu. Otherwise find yourself P06 or JDM P29/P76 ecu
btw. this being shamless plug: I sell kit and chip for $20US shipped
if not simply start here:
http://www.pgmfi.org/twiki/bin/view/Home/WebHome
