suspension question- itr, or si front lower control arms and front lower sway bar???
Hey i just got some front lower control arms, from a guy that i have been buying up all his parts on his hatch, i got the manual steering rack from him, and when i was under the car i saw this big fat lower sway bar, so i got that also along with the lower control arms. I was wondering what i need to install this on my car> and if there are bolt holes in the sub frame on my current 98 dx hatch to bolt the sway bar on to? i figured i needed the lower control arms of his car cause they have mounts for the down links
on the sway bars. i have no idea what control arms these are off of ( si , or itr) he had itr 5 lug on the car but someone got that already and left the front lower sway, and front lower control arms. Lemme know what all i need to put this on? and or if i need to get his sub frame to have the bolt holes for the sway bar>?
Re: suspension question- itr, or si front lower control arms and front lower sway bar??? (louie3252)
if you have the LCA's off of a SI than you will need the SI shock forks too. Yes there are bolt holes on the frame for the D brackets. I put a SI 26mm front sway on my 97 hatch, and all i needed was the Si LCA's, shock forks (don't forget the longer bolts with the forks), and Si end links.
dc2leftovers
07-24-2009 12:27 PM
agent marlon
11-11-2002 04:41 PM
