Auto to manual swap questions
I searched and found a couple threads, but have more specific questions that weren't covered.
This is the main thread I've watched: https://honda-tech.com/zerothread?id=1316692
Couple questions...
Can you use the clutch line, master cylinder, throttle cable, pedals, and the actuator in the tranny from a DC2 GSR?
Can you use linkage from a 90 Integra LS?
Couple questions...
Re: Auto to manual swap questions (jonyb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonyb »</TD></TR><TR><TD CLASS="quote">
Yes (Throttle cable use a GSR cable if your putting in a GSR with a stock IM, if not then dont use that)
Can you use linkage from a 90 Integra LS?</TD></TR></TABLE>
No, there a different lenght.
Re: Auto to manual swap questions (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Thanks for the reply. Keeping the stock D16, so which cable? I read somewhere that the auto one wouldn't work, but then someone said that it would...
If your going to run your auto gas and brake pedal then youll use the auto cable, if your using a manual gas and brake pedal then youll want any manual D series cable (minus D16y7). This is only for 92-95 chassis. 96-00 it doesnt matter.
The car is a 93, and I've got the manual pedals, so I guess I'm in the market for a manual cable. THanks
jacoblytle
11-24-2014 05:14 PM
90efsedan
11-22-2009 08:03 AM
