v-tec help
v-tec help
i had put some ITBs on my 97 civic the first day i felt the v-tec kick in but after that i cant hear it or feel it kick in what do u think the problem could be
Risky Business
Re: v-tec help (cashshoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes »</TD></TR><TR><TD CLASS="quote">i had put some ITBs on my 97 civic</TD></TR></TABLE>
Why do I not believe you?
check oil level even pressure maybe even a blockage in the selenoid after that it can become difficult but need more input
ok i have enuf oil in it i am going to take off the v-tec solinoid and see if it is blocked and i have another question to when i floor it the car cuts out at 6 grand would that meen i need bigger fuel injectors or i need to turn up the fuel pressure i have the fuel pressure on 50 psi o and i adjusted the cam gear if that would make it cut out to
Re: (cashshoes)
did you do any tuning at all? you do understand that ITB's make an engine run completely different from stock, right? ITB's are also complete overkill unless you have monster cams that require that much air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Why do I not believe you?</TD></TR></TABLE>
yeah i did it on a stock d series engine just to see what i could get it to do i go it working and can beat just about any milde tuned turbo engine i just got to get it running perfect do you have any ideas of what i should do
Risky Business
Re: (cashshoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes »</TD></TR><TR><TD CLASS="quote">yeah i did it on a stock d series engine just to see what i could get it to do i go it working and can beat just about any milde tuned turbo engine i just got to get it running perfect do you have any ideas of what i should do </TD></TR></TABLE>
Post pics.
Post pics.
ok i got my v-tec working i had to clen out the v-tec solinoid because it was metal cloging it up now only thing i need to know is. is their anything i can do to tune it or the only thing their is left to do is to take it to the dyno and ima try to put some picks on hear as soon as i figure out how to host them on another site or something
Electron_Blue_Kid
05-26-2006 12:54 PM
Ryan.
10-12-2005 09:11 AM
