ENGINE CACULATOR
Re: ENGINE CACULATOR (SovXietday)
U PUT IN THE SPECS OF THE PARTS U ARE USING TO BIULD MOTOR AND IT TELLS U THE COMPRESSION AND CLEARENCES
Re: ENGINE CACULATOR (SCIVIC94)
well you werent very pacific on what engine you were running but heres b-series http://www.c-speedracing.com/h...c.php and heres d-series http://www.knology.net/~jediklc/dcalc.htm but whats wrong with zealworks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">U PUT IN THE SPECS OF THE PARTS U ARE USING TO BIULD MOTOR AND IT TELLS U THE COMPRESSION AND CLEARENCES</TD></TR></TABLE>
Turn off the caps lock. I thought you were talking about something else, haha, sorry. ^Those guys covered it though.
THE ZEALWORKS IS WAY OFF FROM THE CSPEED.ZEAL SAID I WOULD HAVE AROUND 14:1 COMPRESSION RUNNING AN LS BLOCK WITH CTR PISTONS AND A GSR HEAD. C-SPEED SAYS 12.2:1.
WAY DIFFERENT.IF ANYBODY KNOWS ANOTHER THROW IT MY WAY.THANKS
Ive always found zealautowerks to factor in the most detail, so it *should* give you a more accurate reading. but then again im using it for D series, but i would expect the same accuracy in B
and do mind the capslock please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">THE ZEALWORKS IS WAY OFF FROM THE CSPEED.ZEAL SAID I WOULD HAVE AROUND 14:1 COMPRESSION RUNNING AN LS BLOCK WITH CTR PISTONS AND A GSR HEAD. C-SPEED SAYS 12.2:1.
WAY DIFFERENT.IF ANYBODY KNOWS ANOTHER THROW IT MY WAY.THANKS</TD></TR></TABLE>
calculators are bullshit you need to figure it out yourself
and stop TYPING IN ALL CAPS ITS ******* ANNOYING TO READ
Re: ENGINE CACULATOR (GarageAlchemist)
Does someone need a hug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist »</TD></TR><TR><TD CLASS="quote">try actualy building something, instead of toying around on the internet fantasy tunning...</TD></TR></TABLE>
ITS NOT FANTASY TUNING.UNLIKE SOME PEOPLE.I DONT HAVE A TON OF MONEY TO BUY **** AND HOPE IT WORKS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">ITS NOT FANTASY TUNING.UNLIKE SOME PEOPLE.I DONT HAVE A TON OF MONEY TO BUY **** AND HOPE IT WORKS.</TD></TR></TABLE>
WTF is your problem. People HATE reading caplocks for a reason. Turn that **** off you *******.
ninor
02-08-2007 12:29 PM
