What else to replace when installing new tranny & axles?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'm going to be putting in a no-grind D16Z6 tranny and some Autozone axles in my car in a couple of weeks. What else should I be replacing when I do this install?
So far I've thought of:
- tranny fluid (duh )
- axle seals
- clutch fluid (for when I bleed the clutch?)
Anything else? I hate trannies.
- axle seals
Location: Land of the Hillbillies and Shotguns, Ontario, Canada
Re: What else to replace when installing new tranny & axles? (boostincoupe)
Make sure the input shaft is smooth clean and rust free ( the shaft on which the clutch slides on). Do not grease the shaft however, as it will get all over your clutch and cause slippage. Use a wire brush etc if there is any rust or so on the input shaft.
i recommend using Honda Manual Tranny oil, or even better GM Synchromesh (you should see the threads of great comments of this stuff). That's all I can think of best of luck with the replacement man!
Re: (japan4racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japan4racing »</TD></TR><TR><TD CLASS="quote">unless you are strapped for cash might as well do a clutch while you are in there.</TD></TR></TABLE>
I already put in an ACT HDSS 2 summers ago. This time I need to replace my tranny, as it's going bad. My clutch is still good.
