z6 & Y8 Oil pan: THe same?
Really? IS the shape different or is the entire part different? I was gonna buy a tapped oil pan as a deal but if it wont work then there's no reason. clear this up for me plz!
Risky Business
Re: (shifty35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifty35 »</TD></TR><TR><TD CLASS="quote">The whole thing is different, you can't swap them at all. Period.</TD></TR></TABLE>
the y8 oil pan will fit the z6 block ONLY if u changed the oil pump and pick-up to the y8, BUT the z6 pan will not work on the y8 because u will not have a dipstick anymore
Re: (8secEg)
from what i understand the y8 oil pumps arent as efficient as the z6 pumps do to a change in the design. I have a 2000 non vtec engine that i will be mating with a y8 vtec head, so im wondering if i can put in a z6 oil pump. thanks.
Re: (sirsol66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirsol66 »</TD></TR><TR><TD CLASS="quote">thank you! I just saved a BUNCH of money by you telling me that. </TD></TR></TABLE>
yea i made that mistake once before
I cursed out BauleyCivic and got banned
Re: z6 & Y8 Oil pan: THe same? (hondastreets1)
ya but y7 pans fit haha dont tell me its not because i have 2 in the garage that im swapping back and forth and i took both motors apart
Re: (8secEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8secEg »</TD></TR><TR><TD CLASS="quote">the y8 oil pan will fit the z6 block ONLY if u changed the oil pump and pick-up to the y8, BUT the z6 pan will not work on the y8 because u will not have a dipstick anymore</TD></TR></TABLE>
It also won't seal against the Z6 rear main seal carrier.
Unceasing Measure
Re: (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">whats so bad about the y8 oil pump?
?</TD></TR></TABLE>
They're notorious for failing under heavy-duty useage.
?</TD></TR></TABLE>
Location: So Cal where old pople try to race you, U.S.A
Re: z6 & Y8 Oil pan: THe same? (sirsol66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96accordlxf22b2 »</TD></TR><TR><TD CLASS="quote">ya but y7 pans fit haha dont tell me its not because i have 2 in the garage that im swapping back and forth and i took both motors apart</TD></TR></TABLE>
so y7 and y8 oil pans are the same?
