obd1 dist to Obd2 Harness *seached plenty
Im doin a b20vtec in a 2000 civic ex and am using an obd1 dist. Ive looked through various threads on obdb2-0 , or single cam obd1-0 and plenty others but havent found a thread about the same issue im having. Im pretty much wanting to repin my B16 vtec obd1 dist to work with my 2000 ex harness,so it can be a plug and play affair. I need to know wat colors go to wat. the obd2 dist has 8 wires and the obd1 has 9 . can anyone help? thanks
heres wat im workin with:
copy and paste it into your brower and add the extra W before the link. ww.i46.photobucket.com/albums/f142/stinkyslinky/plugg.jpg
* UPDATE!!!!!!!!!!!!!!!!!!!!!!
ok. I have gotten many responses and Pms , the only thing is people are tellin me different colors do different things. they mention orange wires, which im assumin are the tan lookin wires on my dist. can anyone get a DEFINITE answer to wire in :
OBD1 B16a Distributor into
2000 civic EX engine harness OBD2B
anyone please thanks
Modified by Ch3mik at 4:06 PM 4/5/2006
Modified by Ch3mik at 5:43 PM 5/20/2007
damn, it's not. It's OBD2a.
This should be correct:
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
BLK/YEL=BLK/YEL (On the obd1 2 wire plug)
WHT=BLU/YEL
RED=WHT/BLU
BLK=WHT
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
BLK=WHT
Re: (CivicSpoon)
so then let me make sure i got it right, the diagram you posted . you mean
OBD2B equaling the engine harness wires right? and obd1 equaling the dist plug wires right? thanks man
Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon »</TD></TR><TR><TD CLASS="quote">damn, it's not. It's OBD2a.
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
BLK=WHT</TD></TR></TABLE>
what about the blue wire that sits by itself on the drvr side near the firewall? you didnt list that one in the diagram
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
Re: (Ch3mik)
That blue wire isn't connected to the OBD2b plug, so I didn't put it in the list. But it's the other wire on the 2-wire OBD1 plug. When that plug is hooked up, the Black/Yellow wire will be on the bottom and the Blue wire will be on top; like this
Pic taken from one of B18C5-EH2's thread.
Re: (CivicSpoon)
I ended up usin both the male and female ends of the obd2 plugs. ill get a pic of everything i have. car started up , just throwin a CEL and i need to find out how to get the codes to come up .
Re: (Ch3mik)
I thought they are the same exact color codes, just two other wires goto the other plug.
also you could just order an adapter http://locashracing.com/store/...be64e
i just can't figure out where the conversion chart is located.
Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">I thought they are the same exact color codes, just two other wires goto the other plug.
thats for an obd2a plug. this is obd2b :/
Re: (CivicSpoon)
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
I have it hooked up like this and its misfiring, the timing is dead one, the valves were just adjusted, the plugs and wires are fine, weve tried 2 distributors . anyone have an idea of wat else it could be? im getting no CEL and all the threads i found on misfiring point to all the stuff ive checked already. :/
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
Re: (IntegraTypeR)
it ended up being the valves causin it to misfire. they were so far outta spec.
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
is the correct way. the blue wire gets connected to the single blue wire by itself on the drvr side close to the firewall. its a single wire with a plug on the end , with a rubber cover on it. its mounted on a small bracket. you cant miss it. I just depinned the wire and ran the blue dist wire up to that one underneath the manifold
OBD2B=OBD1
YEL/GRN=YEL/GRN
BLU=BLU/GRN
GRN=ORN/BLU
YEL=ORN
WHT=BLU/YEL
RED=WHT/BLU
RageCivic
90
04-25-2014 01:27 PM
