alternator issues HELP!!!
I have a 94 civic hatch with a b16a2 my alternator went bad,so I ordered a new 1 from a 94 delso vtec cause they have b16's, my problem is when I put the bottom bolt in the top doesnt line up rt...did i order it from the wrong yr car, cause the 1 that was on there lined rt up.....any help would b greatful
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">did you convert to an OBD1 alternator when you did the swap? If you didn't the plugs will be different for sure.
I thought the mounting was the same but I'm not 100%.</TD></TR></TABLE>yes its OBD1 I have it hooked up but with just 1 bolt (top1 )
Re: (top end tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top end tuner »</TD></TR><TR><TD CLASS="quote">try an alternator from a 99-00 honda civic si those have b16a2 obd2 alternators</TD></TR></TABLE>I did but I have OBD1
Re: (top end tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top end tuner »</TD></TR><TR><TD CLASS="quote">when you bought the motor did it come with the stock alternator or an aftermarket one</TD></TR></TABLE>I believe it was a stock 1, so I ordered a 94 delso vtec alternator cause it has a b16 and I figured they were the same,I got it hooked upnow eith 1 bolt but like I sais if I put the bottom bolt in the the top part doesnt line up, so I just got the top bolt in for now until I get the rt bracket or alternator
Re: (hondachris1994)
well not the alternator brackets probably because you have an obd1 alternator and are trying to put it on the obd2 motor (p.s. see if you can order a del sol alternator bracket if you can)
Re: (top end tuner)
I just bought some B series brackets for $25 here on H-T...when I get them hopefully they r different from the 1 I got now
Uniquerootz
10-02-2007 11:40 AM
white90rexsi
01-02-2007 07:55 PM
gezer
09-03-2004 05:17 PM
