climate control in glove box
Re: climate control in glove box (rigles1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rigles1 »</TD></TR><TR><TD CLASS="quote">its possible to move the climate controls into the glove box? has anyone done this to an eg before? </TD></TR></TABLE>
You're going to need lots of tool and time to do this **** !
Re: climate control in glove box (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistermark »</TD></TR><TR><TD CLASS="quote">i have seen someone relocate the Climate control however down to where the radio is, and move the radio down to those JDM audio consoles</TD></TR></TABLE>
a friend of mine is into doing **** like that and he did his on his own and had no problems. everything is long enough to just move it over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">............. why?</TD></TR></TABLE>
i jus wanted to do it cuz i wanted to vafc in its place..
but yeah.. so no one here has actually done it themselves? i believe the cables are long enough its jus getting them in the glove box is the problem.. haha.. thas why i was jus wondering if anyone has done it so i dont waste my time trying..
or does anyone else have anyother suggestions on where i can place a vafc?.. a place where it looks "clean" and not out of the ordinary..
its a 94 eg
its a 94 eg
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">A good place is mounting it above the rear-veiw mirror, or getting a jdm audio console and a double-din blockoff and flushing it into that.</TD></TR></TABLE>
jus went on ebay and checked it out.. that is some good **** man.. good call.. i never knew they had a jdm audio console.. straight.. thanks again..
oh yeah.. i have an si and that lil sunblocker thing above the rear-view would be a good place also.. a lot cheaper too.. u think thas an easy job? cuz i have to extend all the wires eh?
Re: (rigles1)
i woudln't go thru all of that trouble JUST to put a damned vafc in its place, when you can see MUCH better gains using other tuning methods. I.E. hondata, crome(free), uberdata, neptune, AEM EMS, a'pexi Power fc
Re: (instrument)
I moved mine down to the audio console for a while... but the cable had a strange bend so it was very hard to use the slider. You could probably make some modifications to the cable to make it work better, but I never bothered... and just ended up putting it back to stock.
HT White Ops
Re: (rigles1)
What you do is make a bracket that will bolt on to the same bracket the rearview mirror bolts to, a-la JDM roof console:
Just make the bracket shorter, and of course, like an upside down "L". It can be made to look really professional. Basically, make an l-bracket that will fit over the bolts under that cap just like the one pictured above. Then angle downward, so you can see it when you look up.
For the wires, run them under the bracket you make, into that cap, and then under the headliner to the passenger side a-pillar. Then down the a-pillar, through the dash, under the ecu. Boomslang fabrication can make you a harness, just tell them approx how long you want it to be.
Re: (Daniel-sanB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel-sanB1 »</TD></TR><TR><TD CLASS="quote">WTF is that thing ?</TD></TR></TABLE>
http://yhst-1408381693991.stor....html
Re: (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">
http://yhst-1408381693991.stor....html</TD></TR></TABLE>
It's just one ugly piece of sxxt that honda make for ek
