ODO Rollback to 000000?
I'm looking to rollback my odo to zero. This is for a 95 Hatch, SI cluster. I know its illegal, and all that BS, so don't bother. I just need to know if there is a faster way then literally rolling it back mile by mile? Its all apart already. If not, I think I'm going to get a dremel on it with a rubber bit on the gear. It will work, but I'd rather a less dangerous for the odo method. Thanks!
I'm swapping in a motor I built with ZERO miles on it, and would like the cluster to reflect this. Call it a novelty, thats what I want.
Re: (chrisw85)
yea, its the daily. You can't roll them individually. there are some gears inside the roll on numbers. No idea how to take it apart... I think it needs to be broken to be disassembled. I think I'm stuck manually doing it, but want to see if anyone has anything to say. I know some other clusters you can disingage, but not this one.
Re: (banzai_ESG)
there are write ups, but they are integra, or about swapping the speedo in clusters. The Integra is different, and much easier. The search yeilded nothing helpful regarding my question.
Ek Forever y0!
Re: (Eyal 951)
use two dentist picks. You should be able to pry | | | the bold ones apart and move the not bold one. That's how i've seen it done. It works in Ej/ek clusters so I'd think it would workin yours. You just have to pull it back far enough so the pin in the middle spins freely.
JDMJUNKIEMONKIE
11
02-02-2010 09:41 PM
Dam itz Lou
12
11-09-2009 10:17 AM
