1,2,3 probLems: brakes, carbon fiber repair, running lights
Hey there, i have 3 problems that need to be fixed:
1. Driver side Front Brake makes a Squeak/Squeel Noise when the tire rotates.
2. Carbon fiber hood popped up on me in the freeway, did not shatter my windshield but the hood is very Flimsy now. Looks like all the hard glue holding it together snapped in half or something.. i was thinking of using a heatgun and melting all the glue and then applying more glue?
3. My running lights wont come on
Help me out please, thank you.
Modified by efocmacro at 1:59 PM 9/6/2006
Re: 1,2,3 probLems: brakes, carbon fiber repair, running lights (efocmacro)
1. Replace pads and rotors
2. No clue
3. Fix sidemarker and replace fuse.
You have 478 posts and you still post crap like this?
Modified by PhatBoy5015 at 1:48 PM 9/5/2006
2. No clue
1st you probable need to put new brake pads on the car the squeaking sound your are hearing is there because the pads are almost worn out. NEVER SPRAY WD40 or any lube on a braking surface. It will only cause problems.
2nd not sure I have never worked with carbon fiber. I do know that they use a vacuum to force the glue into the fibers.
3rd did you replace the missing light assy and check for and replace the blown fuses?
1. I hope spraying the WD-40 was just a joke. That is the worst thing I think I ever heard. ***FIX*** replace pads. At this point you may need to work on the rotors too.
2. Good luck
3. Check your fuses.
2. Good luck
problem #1 - you need to replace the pads and rotors.
problem #2 - for the hood, you should have had the hood locks. they will have prevented this from happening (actaully i believe it was probobly advised when you purchased the hood). you most likely need a new hood.
problem #3 - inspect the wirings to the lights, fuses, and the bulb itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efocmacro »</TD></TR><TR><TD CLASS="quote">wtf dont call my posts crap, they are serious problems</TD></TR></TABLE>
I said it was crap because this is basic car knowledge that most WOMEN know. You should already know that you need to change pads and/or rotors. And you should know how to check and replace a fuse.
Re: 1,2,3 probLems: brakes, carbon fiber repair, running lights (PhatBoy5015)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">
I said it was crap because this is basic car knowledge that most WOMEN know. You should already know that you need to change pads and/or rotors. And you should know how to check and replace a fuse. </TD></TR></TABLE>
BULL ****.
youre fat.
the end.
BULL ****.
youre fat.
the end.
BULL ****.
youre fat.
the end. </TD></TR></TABLE>
Awesome. Did you come up with that all by yourself?
BULL ****.
youre fat.
Awesome. Did you come up with that all by yourself?</TD></TR></TABLE>
i think the worse part is that he sprayed WD-40 on his braking surface good way to help natural selection along
Re: 1,2,3 probLems: brakes, carbon fiber repair, running lights (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
i think the worse part is that he sprayed WD-40 on his braking surface good way to help natural selection along</TD></TR></TABLE>
Haha. That ***** pretty damn funny.
So you figured you would reduce friction on your brake pads to make them stop squeeling?
Brilliant.
Brilliant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efocmacro »</TD></TR><TR><TD CLASS="quote">what are u talking about i didnt even spray any wd40 on my brakes</TD></TR></TABLE>Did you spray it in your ear and into your brain maybe?
Your questions are easily answered with common sense and logic.
Re: 1,2,3 probLems: brakes, carbon fiber repair, running lights (Enerjohn)
i wasnt sure about the squeeling to be honest with you ... thats why i asked... can i ask questions on a technical forum without being e-mobbed, jesus christ
the carbon fiber repair and the running lights are common questions too
if i dont know something ill ask and thats how its always gonna be
thanks **** ****
thanks **** ****
Dumbass, it says "Modified by efocmacro at 11:38 AM 9/6/2006" at the end of your first post. You thought you'd be slick and edit out the part where you sprayed WD-40 on your brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">Dumbass, it says "Modified by efocmacro at 11:38 AM 9/6/2006" at the end of your first post. You thought you'd be slick and edit out the part where you sprayed WD-40 on your brakes. </TD></TR></TABLE>
dude wtf are u talking about i edited my typo i spelled brake, break
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efocmacro »</TD></TR><TR><TD CLASS="quote">dude wtf are u talking about i edited my typo i spelled brake, break</TD></TR></TABLE>
Dude we all read it where you said you hosed that **** down with WD-40. Notice my first reply that I referenced it too. I do have to say that editing that out was far smarter then do in it and farther smarter than telling people you did it.
Best of luck on your repair work.
Willard
16
01-25-2002 06:00 PM
