TEIN S-TECHS ON TOKICO ILLUMINA STRUTS
i was wondering if anyone had a set of tein s-tech springs on tokico illumina struts and how they rode. or what would be a good strut setup with tein s-tech springs.
BUMP IF YOU VIEW
BUMP IF YOU VIEW
i have the teins s-tech but on kyb-agx i like the ride. not too stiff yet good enough to through in the corners a bit. ive heard bad things from tokico and stayed away from them. you can find fome agx for cheap on ebay
got the tein s-techs mated to some koni reds. Definitely an improvement over stock, not a horribly low drop, and it's my daily so it's exactly what I need. Konis are good shocks, but they might cost a little bit more. My whole setup ended up being around $430.
Former Moderator
Re: TEIN S-TECHS ON TOKICO ILLUMINA STRUTS (iamthecolt45)
I have Tein S-Tech springs mated with KYB GR-2 non-adjustable struts on my daily driver and the ride is excellent.
I'd stay away from Tokico - I've nevewr driven a car with Tokicos that I liked, and I have driven a lot of cars on tokicos seeing as how I've been at my shop for 6 years now and all we do is Hondas/Acuras with a lot of lowered car alignments, suspension installs, etc.
IMO:
Koni>KYB>Tokico
I say Koni is better for sure, but for S-Tchs KYBs are awesome and much cheaper.
IMO:
Koni>KYB>Tokico
Re: (mugenej8power)
S techs are going to feel slightly tighter than stock. It's by no means a performance spring. It's too soft for that. It has in mind comfort and a lower stance, a 1.5" lower stance, that is.
Re: (J.MONEY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.MONEY »</TD></TR><TR><TD CLASS="quote">S techs are going to feel slightly tighter than stock. It's by no means a performance spring. It's too soft for that. It has in mind comfort and a lower stance, a 1.5" lower stance, that is. </TD></TR></TABLE>
however if u weigh anything more than 150 lbs, once you sit in the car, the fender will be right above the tire. it looks perfect, i cant say the same about performanc.e
HT White Ops
I had tech's on illuminas. It was a nice ride, but it didn't handle much better than stock. I switched out to some H&R sports, and it sits a little higher, but handles quite a bit better.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I had tech's on illuminas. It was a nice ride, but it didn't handle much better than stock. I switched out to some H&R sports, and it sits a little higher, but handles quite a bit better.</TD></TR></TABLE>
Currently sitting on sports with kyb's. I don't like the ride hight but it was much better then stechs.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamthecolt45 »</TD></TR><TR><TD CLASS="quote">i was wondering if anyone had a set of tein s-tech springs on tokico illumina struts and how they rode. or what would be a good strut setup with tein s-tech springs.</TD></TR></TABLE>
That's a very mild setup. The ride will be similar to stock. Handling will also be similar to stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">BUMP IF YOU VIEW</TD></TR></TABLE>
We don't do that **** here.
jdm-addik
02-12-2009 06:54 PM
dc5 paoer
01-07-2006 08:38 PM
