can i use a p75 in place of my p72? are they the same connectors?
Re: (pdiggitydogg)
aight so i guess i asked the wrong question, i was under the impression P75 was a typeR ecu, will a Type R ECU hook up inplace of my GSR ECU, OR do they have different plugs???? simple question for someone who knows
ok, ecus's....
Is your gsr
obd1
or
obd2a or obd2b?
the itr ecu is obd2b only
SOO unless your gsr is obd2b, it wont work without a jumper
youre being too general with your questions............there is more than one answer
Is your gsr
obd1
or
obd2a or obd2b?
Re: (pdiggitydogg)
see thats what i needed to know, i have an OBD 1 GSR ecu, i was told from another person that i could buy there OBD 1 type R ecu and it would run fine, i then talked to another that said it was not possabe, soo what i got from this is, there is no OBD 1 type R ecu, even if i was running an OBD 2 car, it would not work because its OBD2b, thank you very much you have saved me some money
HT White Ops
A P73-003 is a JDM OBD2a ITR ecu, and a P73-G01 is an EDM OBD2a ITR ecu.
All USDM P73's are OBD2b.
If I may ask, why do you want to run an ITR ecu? Did you change out your intake manifold, and you'd rather just swap the ecu than chip one?
HT White Ops
Re: (1995sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995sir »</TD></TR><TR><TD CLASS="quote"> thanks fellas is it worth paying 75$ for a p73 ecu and reselling it? asuming its a USDM</TD></TR></TABLE>
Possibly. I don't know how much USDM p73's cost, but JDM ones run $200+
HT White Ops
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">it p73 would check and throw code for secondary o2 though, since your obd1 teg doesnt have it</TD></TR></TABLE>
Touche'
Touche'
