5th gear 82 MPH at 3.9-4.0 RPM is that CORRECT?
I have the feeling my MPH is off by like 5+ miles or so. I was cruising on the freeway today and did aroun 85 MPH and the RPM read 3.9-4.0 on 5th gear. the tranny is a S4c. Motor is a B16A1 (JDM) in an EM1.
HT White Ops
Re: (1bar_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar_ek »</TD></TR><TR><TD CLASS="quote">Sounds right. Your si tranny runs on shorter gear ratios than the ls tranny, so of course you're going to be on higher rpms.</TD></TR></TABLE>
No dude, he's saying he's running around 4k @ 85, and that's about what I run on an LS tranny. His RPM's should be higher.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
No dude, he's saying he's running around 4k @ 85, and that's about what I run on an LS tranny. His RPM's should be higher.</TD></TR></TABLE>
My bad, wasn't reading it correctly.
Unceasing Measure
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">No dude, he's saying he's running around 4k @ 85, and that's about what I run on an LS tranny. His RPM's should be higher.</TD></TR></TABLE>
Depending on...
Depending on...
Littering and...
His tire diameter.
Depending on...
Depending on...
Littering and...
His tire diameter.
HT White Ops
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Depending on...
Depending on...
Littering and...
His tire diameter.</TD></TR></TABLE>
This is true. But stock for stock, his is off. Chances are he has teh uber jay-dee-em 18's.
Depending on...
Littering and...
Darth ModerVader
Re: 5th gear 82 MPH at 3.9-4.0 RPM is that CORRECT? (Nameless Warrior)
Even if the tires are a different overall diameter, the indicated speed at a given RPM will be the same.
Re: 5th gear 82 MPH at 3.9-4.0 RPM is that CORRECT? (Padawan)
LS MESH on GT QUALITY 195/55.
I was testing it out earlier and I am off by like 12 MPH. What would cause my MPH to be off by that much?
EDIT: On my way home from work they havec like a radar that tell you how fast you're traveling. On my GAUGE it show I am doing 59 but on the radar it show something like 47.
Risky Business
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Littering and...</TD></TR></TABLE>
Do you have any idea how fast you were going?
Unceasing Measure
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Do you have any idea how fast you were going?</TD></TR></TABLE>
65?
65?
HT White Ops
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">65?</TD></TR></TABLE>
63.
63.
Re: (Eran)
63.</TD></TR></TABLE>
But isn't the speed limit 65 officer?
Cruising at 80 mph, my rpms are at about 4.5k. JDM B16 w/ matching tranny.
-Shane
-Shane
Re: (nighttrain33)
WhoaAA whoAaaa whoAaAa!
Lets not forget I got a problem here.
okay, so the possibility is false spdometer or VSS?
HT White Ops
Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">But officer, isn't the speed limit 65?</TD></TR></TABLE>
Yeah.
It is.
Yeah.
It is.
HT White Ops
Re: (oneflybiker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneflybiker »</TD></TR><TR><TD CLASS="quote">dude that's about right with the S4C......now the Y1 or YS1 trans would be be at like 4800 to 5k ..and to the dumbass with the LS tranny long gears you would need to drop to 4th and punch it to see 82....lol</TD></TR></TABLE>
Are you retarded, or just 13?
Have you even driven a car? I can make it to 82 in 5th from a 60 with a Y7.
Re: (Nameless Warrior)
Well, unless your speedo is waaaay off (speaking off from the factory), there is no way that the tires you are running would affect your speedo by 12 mph. So yeah,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Faulty spedometer or VSS.</TD></TR></TABLE>
-Shane
-Shane
Re: (oneflybiker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneflybiker »</TD></TR><TR><TD CLASS="quote">..and to the dumbass with the LS tranny long gears you would need to drop to 4th and punch it to see 82....lol</TD></TR></TABLE>
O RLY? I hope you are kidding. I don't know of a car that won't make it to 80 nowadays.
-Shane
-Shane
