nsx brakes???
nsx brake swap with factory hub???? * fix'd *
well me and a buddy are into roadracing and we came across nsx calibers and rotors for an nsx at the auto parts store wich is where my friend works ..anyway has a nsx brake swap ever been done...with adapter plates for the calibers and having the rotors machined to fit i think i could be possible....let me know what you guys think..i was going to do this as a project and post it up but i wanted to see what you guys had to say about it before i wasted money trying to do it ...think it would be a good project?
ps: the car i was going to try it on was a ej1 ...and i want o keep the factory hub and bolt pattern 4x100
Modified by turdb0 at 12:28 PM 11/16/2006
i was thinking about trying to keep the 4x100 set up and have the rotors machined and have holes drilled to match the factory USDM bolt pattern...or will the usdm suspension get in the way?
Re: nsx brakes??? (turdb0)
NSX caliper swap. This link looks like it's for a ''96-00 swap, but the OP's would know more about that. I have been wanting to try this as well.
-Shane
-Shane
thanks for the info nightrain...has it been done with a 92-95? and is it possible to keep the usdm suspension and bolt pattern?? or is a itr or ctr swap needed??
Re: (turdb0)
Best info available. Will work with your car since your EJ1 has the same knuckle as the Integra.
https://honda-tech.com/zerothread?id=1811368
i know its possible but i wanted to know if anyone has ever had the rotors drilled out to 4x100 to fit the factory usdm hub...im not going to swap the hub ...has anyone ever done the brake swap using the factory hub??
Re: nsx brake swap with factory hub???? * fix'd * (turdb0)
I have a set of nsx rotors that have been drilled to 4x100 we were going to put
them on my buddys ek hatch then decided to just do si brakes cause he didnt want to go to a bigger wheel.
they line up perfect just need the adapter plates to mount the caliper we also didnt
have those
have those
Re: (turdb0)
sneak peek of what is sitting in my garage...front and rear nsx calipers!!!
swapping 4x114 + some nsx calipers
btw its going to be an 11inch setup under 96 jdm itr 15inch wheels on a 91 crx hf
been there done that
Re: (ozrednsx)
you can use the nsx calipers but the rotors are too big. also if you use 94-95 legend gs rotors redrilled to 4x100 you dont have to modify the caliper bracket.
https://honda-tech.com/zerothread?id=734560
