lowering problems ahhh!!!
ok guys so i have tein s techs and for some reason the left side sites higher not by much but i notice it and it bothers me and iv done everything to try and fix this problem i switched sides still does it and also reseated the springs but still nothing so i was looking at getting new springs but im not sure how low i can go i like how low the teins are but there not very stiff so i was wondering how low i can go and a good spring rate thanks guys
Re: lowering problems ahhh!!! (stock ek)
Maybe its your shocks and not your springs.... and buy the way whenever you lower your car you always have something in the back of your mind that tells you its not even... forget about that. Put the car on even ground... then see if its still like that. If it is still like that check the shocks and align the car. Im about 98% sure that the springs are not the problem if you said their new. But most likely its your shocks... one side is probably blown or something.
Re: lowering problems ahhh!!! (Midori Green)
your probly right i think one of my shocks is blown but i never thought that would cause an un even problem soo ill have to check thanks guys
to the best of my knowledge,shocks have no affect on ride height,its the springs that control it.check all your suspension rubber bushes ,shock tops, nuts and bolts etc. also itmight help to jack up the car ,loosen all the shock bolts a little,then retighten them with the vehicle back on the ground,bring it for a good drive on some bumpy roads,to settle everything,then check it again.would deff change the shock also,if your sure its stuffed,but i doubt its affecting ur ride height.good luck.
Re: lowering problems ahhh!!! (bluebeast)
so today when i had my car on the lift the shock was blown but then i also relized that the shock dosent have an affect on the ride hight like blue beast said so im going to go thru and loosen and and retighten all of the bolts as well as change the shock cuz its blown soo will see how it goes
crxaddikt
09-06-2002 05:41 AM
