Mid-swap crisis
Mid-swap crisis
Okay i dropped my motor in today and i made sure all the mounts were on correctley and my hood wont shut, the motor is sitting too high to shut the hood. Its a b16 swap from hmotors with the hasport mounts made for a 94 del sol, or thats what i ordered they came in a box that says 92 civic. So are the mounts the same for a 94 sol and a 92 civic or did they send me the wrong ****? and is that the only possible reason for my motor to be sitting so high?
This is a relatively common problem with swaps.
Depending on how high it is you might be able to get away with ripping off the skeleton on the bottom of the hood.
Re: (JdelMsolG)
You can also shim your mounts. Adding 2 washers between the motor mount bracket, and the hasport mount. Do that on the tranny side also. That should move the motor down slightly.
Re: (my_slow_civic)
Good ideas to fix it.. but it shouldnt be that high. Why would it be? I've never seen a B series swap with hood clearance issues. Something must be wrong or your CF hood is misshapen.
Re: (93CX)
i dont know.
im confused too, this is my first swap and i just keep running into little problems like this and its killing my confidence.
i figured it was the mounts making it sit so high. But they are hasports made for the swap. i just dont get it.
it's got to be the hood, try raising the little bushings in the front that adjust where the hood sits.
Or do the washer trick with the mounts. This isn't a big deal at all, don't let it get you down
Re: (Sean @ ESG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean @ ESG »</TD></TR><TR><TD CLASS="quote">it's got to be the hood, try raising the little bushings in the front that adjust where the hood sits.
Or do the washer trick with the mounts. This isn't a big deal at all, don't let it get you down </TD></TR></TABLE>
Could also try shimming the hood up a few washers.
Re: (my_slow_civic)
i have a nopi brand hood that i paid almost 700 dollars for.
so if i buy say, a vis hood it should fix the problem?
Re: (thehatchninja)
okay. so if i attempt to do the washer trick on the mounts what exactley am i doing?
im placing washers between the car and the mount?
in my head its making me think that would raise the motor even more. im so confused.
Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">dOOd b16's dont fit in del sols... jp... i just swapped a b16 in my 94 del sol and did not have any kind of hood clearance... btw, i used the stock mounts</TD></TR></TABLE>
stock D series mounts?
is that possible?
is that possible?
Re: (JdelMsolG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG »</TD></TR><TR><TD CLASS="quote">
is that possible?</TD></TR></TABLE>
haha yes. 93 del sol and civic is the only set of motor mounts that wont accomidate a b-series swap. 94 they stared with the integra style mounts, so you dont need aftermarket ones. even with a 93, the only mounts you need are the L-bracket, and the rear motor mount.
OP: I would shim the hood first. Get some washers and place them between the hood and the mounting bracket for the hood. Should fix the problem.
Re: (JdelMsolG)
Yes, you use the B-series brackets and the D-series mounts
Re: (96-EJ6 B18C)
thanks guys for all the help.
im sure i'll keep updated, ill probably have more problems
it kind of sucks right now though because i have to stall a few days due to everything being closed for christmas.
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">wow, that doesn't look ghetto or anything.</TD></TR></TABLE>
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 »</TD></TR><TR><TD CLASS="quote"> no need to rip the hood a new *******..
..remember, a notch. </TD></TR></TABLE>
Exactly...don't over do it.
haha
j-villani
09-27-2012 01:27 PM
bluedelsol
06-03-2003 06:14 PM
ShortbusEK
05-04-2002 01:21 AM
