Small black smoke in Vtec
I just got some black smoke coming into Vtec. I know too much fuel is in the system. Bone Stock w/ 150K on the motor. You guys think its the Fuel pump?
What are my orders, that I should check?
Fuel pump>Fuel Injectors?
Thanks in advance
Thanks in advance
Re: Small black smoke in Vtec (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">150k jeez give the poor thing a break.
Most important are you running a cat?</TD></TR></TABLE>
Running a cat, compression is strong all around at 157. I'm just embarrassed when smokes comes out. Going to go get a fuel inject leak next week, and test out the fuel pressure. I know old engines tend to be leaky at the injectors or pump.
Re: Small black smoke in Vtec (mrtrinh)
noo..its most likely just blow by oil that gets past ur rings when u get to higher revs...my old gsr started smokin at 133k,so i put new pistons and rings..and it went away after that!!!
Kod Sol
02-16-2005 01:06 PM
