Engine questions
Engine questions
I would think this would make sense, but i would like to ask anyway.
Do all internals out of the same series work together? example:
would d15 crank go in d16, d17
or B series pistons fit B16, B18, B20
i have been searching for a frankenstien engine setup that would result in high compression, because i know some B series rods are longer than other ones.
What are the most popular engine set ups people build for high compression or boost?
Re: Engine questions (hondatm)
No this is not true.
B series pistons are not interchangeable.
A b16 has 81mm bore (I think)
A B20 has an 84mm bore I know that for sure.
This is one way displacment is made. Also B16 and B18 cranks are not interchangable. The b18 ls and a B20 are the same. Im not really sure about the D series motors, but make sure you find out before you start swapping stuff out.
