civic front rotors w/abs and w/o abs..different sizes??
does the size in rotor change if the car comes with abs or not? i thought i didnt have abs on my 96 hb, so i ordered front rotors, but they are too small. so my question is..if the car does come with abs..are the rotors bigger?? thanks in adavnce.
Re: civic front rotors w/abs and w/o abs..different sizes?? (mr abstract)
Do you have the stock brakes on your HB? Can you measure the rotors you ordered and then measure the ones you have? Possible they sent you different ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr abstract »</TD></TR><TR><TD CLASS="quote">my front rotors are 10.25 inches. damn..so i do have abs?</TD></TR></TABLE>
Not necessarily because all Civic EXs have 10.25" rotors. If your car isn't an EX or EX ABS, then the brakes you have on your car were put on by somebody else.
Re: civic front rotors w/abs and w/o abs..different sizes?? (BlueIntegraBoy)
ok..so i have a 96 civic DX hatchback with rear disc conversions. i THOUGHT that the guy that i bought the car from only changed out the rears. so..either i DO have abs on the car (which doesnt work) or he switched out the rears and fronts from a civic ex?
The previous owner of your car got brakes from a Civic EX, Civic Si (EM1), or better yet Integra. Either way, your car does not come with ABS.
However, when you order pads, you'll need to know if you have Civic EX or Integra brakes. A good indication is to look on the knuckle and look for two holes. The two holes indicate that it is from an ABS car (ABS sensor), and you'll need to order pads for an Integra. Also, when you change the rotors, look for the ABS gear.
beer30hatch
03-03-2007 10:36 AM
slow94coupe
01-13-2005 08:28 AM
allmotorEG-SI
09-18-2003 10:03 AM
