valve clearence d15b7
How do you perform valve clearence ajustments on a d15b?
150k on the motor and i havent one clearence check
Please provide a detailed explaination of how to make these adjustments.
Thanks for any useful info in advance
Re: (IslandSi)
thanks but...
let me fully understand this
I will turn the crankshaft until each piston is at the top and make my adjustment to 10ft lbs each time? 4 times? one for each cylinder
^^using the pulleys for refrence on the TDC
Should i remove the spark plugs to check to see piston position or can i just use the gears/pulleys?
Where do i get a feeler gauge?
Thanks again
Thanks again
