who can tell me what thread pitch and size these studs are?? motor mounts...
at the jetties fishin'
finishing up the swap in my civic after 6 months and come to find out that I apparently lost both the nuts from the driver side mount.
it's from a 95 LS engine.
anyone know the size/pitch of these two studs so I can get the proper bolts from the hardware store??
Re: who can tell me what thread pitch and size these studs are?? motor mounts... (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote"> it's from a 95 LS engine.
nothing works like oem....id go to honda personally. since no one seems to know the size for sure.
M12 x 1.25 nut is what you need. Hope that helps, happy holidays
cute little bastard
http://www.acuraoemparts.com/d...ch=no
Well at least I was right about 12mm. I'm not positive if its 1.25 or 1.5. Pretty sure its 1.25 b/c the threads look really fine
Re: who can tell me what thread pitch and size these studs are?? motor mounts... (SkoundrelUSA)
cool deal, I'll grab some up after work today and see if they work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">http://www.acuraoemparts.com/d...ch=no
Well at least I was right about 12mm. I'm not positive if its 1.25 or 1.5. Pretty sure its 1.25 b/c the threads look really fine</TD></TR></TABLE>
wait, according to that picture, the bolts I need are #34 which is saying they are 10mm...
so I'm guessing they are the M10x1.25 that was mentioned earlier...
cute little bastard
I think you're right, I was looking at the passenger mount and thought it was the same thing
m10 is kinda small... lets put it this way, your oil drain plug is m14, so a size down from that seems reasonable.
Re: who can tell me what thread pitch and size these studs are?? motor mounts... (jadugartir)
well, they probably are M10.
Since the passenger side mount uses an M12 nut. I tried using that same nut on the driver side mount and it was definitely too big. Slid right on and then off again.
I'll go grab two M10x1.25 nuts this afternoon. Hell, if they are wrong, I'll just take them back and exchange them...though I really dont want to go back and forth the the hardware store 6 times to get the right nuts lol.
they were M10x1.25, got them installed just a few minutes ago, thanks!!
good to know you got your swap done.....but i have a question....i did a LS B18B swap in my EG Hatch and the mounts that i used for now are the single cam mounts that were in with the D series....well, i have the same motor mount you have pictured there but it doesnt allign with the mount braket thats on the motor....what braket is the one i need so it can allign with that mount???
Re: who can tell me what thread pitch and size these studs are?? motor mounts... (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">The original 94-01 integra bracket.
The reason it doesn't line up is b/c you are using the
d-series bracket.</TD></TR></TABLE>
weird....i got the LS motor with that braket and then i went to a local Junkyard and i picked up a GSR braket knowing that its a GSR mount....but when i got home....i turned out to be the same braket i had in the LS motor which doesnt allign with that mount, only the D series mount..
Re: who can tell me what thread pitch and size these studs are?? motor mounts... (B18CivicEg)
Hmmmm Well you could tell by this. The d-series has to two studs on the bracket.
They integra bracket has two studs and threaded hole for an additional bolt.
Also the d-series bracket has the studs in a slanted position.
Maybe someone else can chime in with a pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">Hmmmm Well you could tell by this. The d-series has to two studs on the bracket.
Maybe someone else can chime in with a pic.</TD></TR></TABLE>
yea...mine have the studs in a slanted position...well...i'll just go back and ask for the integra braket and make sure they're not slanted....
i'll just make sure it has the threaded hole....thanks alot...
Civic Racer X 7
08-29-2014 07:37 PM
GroundZer0 336
06-27-2009 06:01 AM
stackz
12-27-2006 09:49 AM
