HELP! Engine is Putting?
i turned my car on today and during its idle, its putting? kinda sounds like its a cylinder misfire or somthing. when im giving it gas, like on the highway, it seems fine, but once im idling, the engine is putting. rpm drops a bit everytime it does so.
im thinking its either the distro cap and rotor thats old? bad plugs? idle sensor? whats going on with my car? someone help please.
Re: HELP! Engine is Putting? (mikhsoj's ep3-05si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikhsoj’s ep3-05si »</TD></TR><TR><TD CLASS="quote">i turned my car on today and during its idle, its putting? kinda sounds like its a cylinder misfire or somthing. when im giving it gas, like on the highway, it seems fine, but once im idling, the engine is putting. rpm drops a bit everytime it does so.
im thinking its either the distro cap and rotor thats old? bad plugs? idle sensor? whats going on with my car? someone help please.</TD></TR></TABLE>
can't really tell. it can be numerous amount of things.
could be the things you mention, a sensor could be messing up, or worst case scenerio, internals can be messing up as well.
process of elimination, start with the cheapest part to replace and work up from there.
Your car is probably working on 3 cylinders... I had the same problem. First check the spark plugs then if thats not the problem... you probably need some headwork.
djsire
12
09-13-2005 11:46 AM
Aphelion
05-24-2005 09:07 PM
Andrew 825SM
10-20-2004 09:52 PM
AgentJam
08-02-2003 01:23 PM
