help misfiring!!!!!
help misfiring!!!!!
VIDEO OF SAID MISFIRING
http://www.youtube.com/watch?v=INOkZIHSa7Q
i have a 99 dx hatch with a stock d16y7 with an ex exh mani an ex intake mani it ran fine for 2 years then it started misifirng but didnt throw any codes then it started running real rich.
i can disconnect injector 4 and the idle stays the same i can disconnect plug wire 4 and nothing changes and it throws p301,p302,p303,p304 and p1300 and p1399 i just installed a new distributor ,wires, cap, rotor,ngk plugs and injectors and still nothing i turn it on and the cel starts blinking like crazy idles like a subby and sounds like a subby when i hit it
Modified by iNfAmOuS_PuTt_pUtT at 8:45 AM 5/17/2007
so you get misfires on all the cylinders or just #4. I see you get codes for all of them. if its only one cylinder then misfires can be caused by no spark, no fuel, not enough compression. so switch spark plug 4 with 3 and see if the problem stays in cyl 4 or follows the plug. same thing with the inj. perform a compression test.
Re: help misfiring!!!!! (iNfAmOuS_PuTt_pUtT)
many things it could be. how mechanicaly inclined are you. check valves for cracks, not seating, cracked spark plug, shitty spark plug like autolite plugs i see many people use, rotor, cap, wires, compression,injector, injector pulse. and some other stuff im forgetting.
replace and or switch with another cyl. the spark plug and injector.
if not sounds like a head gasket problem. but do a compression check on all four and if the #4 is low you got a problem
have you checked the positon of the plugwires as suggested by gotbooost? check it end to end..
have you experimented on advancing/retard the timing before this problem occurred?
what did you do to your car before this happened?
