Final Build,... Need Tech Advice
I'm a first timer...i'm not a NOOB, but this is MY first build.. and I'm Preparing to Turbo my D16z6 and i'm going to use these products... my budget is around $2000 and this is at $1668 so far, i have the turbo kit so no worries there.. but am i missing anything?
KMS Ultimate Valve Train Package
A set of new Dual Racing Springs, Titanium Retainers,Stainless Steel Racing Valves, Valve Guide seals, and a blockguard.
Price - 599.00
Eagle Rods - D16
These high-quality rods are an inexpensive insurance for turbo/supercharged applications because you know you are going to turn the boost up!
Price - $375.00
KMS Forged Pistons - D16
These pistons come balanced with peened and polished faces to remove dangerous hot-spots and prevent detonation.
Price - $499.95
ARP Sport Compact Head Studs
Honda D16 10mm,, ARP Cylinder Head Studs
Price - $95.99
450cc DSM Injectors
Price about $80.00
i know i'll need a new fuel pump for NOS, so what is reccomended? what else is needed?
I'm trying to make it handle about 12Psi, and 15-18Psi plus a 75 shot at the track.
Price - 599.00
Eagle Rods - D16
Price - $375.00
Price - $499.95
Price - $95.99
450cc DSM Injectors
Price about $80.00
Re: Final Build,... Need Tech Advice (1d10t)
over kill is good, especially on pump gas. i ran a built d16y8 on 22psi daily on rc750cc and hondata s300 with a plx m300 wide band
1 Post
Those 450's will be fine on what he will be making. This is a D series motor with pistons and rods, not a sleeved H with a T04R. probably looking at around 300whp on a good day with the setup with no bottle and I personally made 320 without stressing a set of DSM 450's. Still at 90% DC.
Walbro 255 will be more than enough fuel pump for that setup so you will be good there. Only suggestion I could make would be ditch the block guard, it's not cheap insurance, it's not even insurance. If it's going to split a sleeve, it's just going to do it lower with a block guard than without. Still going to break.
Use the 100 bucks you would have spent on that and get an extra hour of street tuning to make sure it's going to be safe and you will be fine.
Re: Final Build,... Need Tech Advice (doood)
that's cool, but i have no idea what my horsepower will be @ so... i guess ill get 550's and dyno it, and go from there. but am i missing anything else? how much is sleeving and do i need it?
****... well i guess i don't have much of an option.... some one reccomended a ramhorn intake manifold? i'm not sure if thats right but they said its a huge benefit. then tune with Neptune...
1 Post
Re: Final Build,... Need Tech Advice (Vaw7er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vaw7er »</TD></TR><TR><TD CLASS="quote">that's cool, but i have no idea what my horsepower will be @ so... i guess ill get 550's and dyno it, and go from there. but am i missing anything else? how much is sleeving and do i need it?</TD></TR></TABLE>
I have repeatedly seen RC 550's (saturated) and DSM 450's (peak and hold) hit about the same whp mark at the same AFR at 90% DC. What is your overall goal for the car powerwise.
Better yet, what size turbo are you putting on? I can give you a better idea that way.
Re: Final Build,... Need Tech Advice (Jay_Sensing)
i'm not sure... i've never seen anyone build a D16Z6. so i'm not sure. it's not gutted at all, in fact i have competition subs in there... i'll just take it to the track on the weekends and cruise with it during the week. i"m looking for mid 11's to mid 12's.
90% duty cycle is dangerous. good way to flutter the pintle. Yea, go ahead, go cheap. youll be sorry. 18 psi and 75 shot of nos is too much for 450cc. even rc recommends 80% be the MAX.
according to rc technical website....450cc @ 90% Duty cycle can only handle 255 BRAKE hp @ .65 bsfc with 50 psi. thats about 11-12 psi on a z6. ( with a decent turbo) 550cc can handle closer to 300.
buy some 750s if you dont use the full capacity of the inector it can be tuned out. then if you upgrade later on you will still have some left over injector.
