Rear disk brakes? Did I get lucky?
My LX has rear disk brakes, I hear a good bit of talk about swaping to rear disks on civics. Did I get lucky or did all the 92-95s get rear disks?
Modified by iceman7329 at 7:19 PM 5/3/2007
Re: (Jay_Sensing)
Well, Im going to do the brakes soon. What do I get the pads for then? Just an EX or SI if it has those brakes on it? Ill get a pic tomorrow when I change my wheels.
Re: (iceman7329)
I also need a new master cylinder. As always I see this as a time to upgrade, should I? If so what whould be the ideal master cylinder/booster to go with for the 4 wheel disk?
1 Post
Re: Rear disk brakes? Did I get lucky? (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">I was pretty sure lx's came with rear disk brakes?
Maybe that's just ek's.</TD></TR></TABLE>
Ah, that I didn't know.
<----- is not a brake guru, only went off what I have seen. Sorry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">You have the LX model with ABS. All ABS model on 92-95 came with rear disc.</TD></TR></TABLE>
It has ABS.
It has ABS.
Re: (ek forever guy)
i got an lx and it didnt come with disc brakes all around, i got rear drums. but i will be doin my brakes soon. so i guess u got lucky
Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">What year. If 96-00 only drum. 92-95 had option disc or drum.</TD></TR></TABLE> I dont know, the fact its in my sig and I also said 92-95 in my first post must mean its a 92-95, right?
Re: (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 »</TD></TR><TR><TD CLASS="quote"> I dont know, the fact its in my sig and I also said 92-95 in my first post must mean its a 92-95, right?</TD></TR></TABLE>
I was asking jimbo_690
But yeah. Since you had metion you have ABS it came stock. You have the LX model with ABS optional.
Re: (kaiba)
I was asking jimbo_690 </TD></TR></TABLE>
Oh, sorry
Oh, sorry
Re: (iceman7329)
Best master cylinder upgrade would be a 91 Civic Si 15/16 master cylinder. There are 1 inch Integra master cylinders available, but there is no measureable gain between the 15/16 and a 1 inch. And it's more work while the 15/16 is a bolt-on replacement.
I don't know how that will affect your abs though. In fact, even changing to stickier tires and bigger rims can affect the abs...
Re: (suspendedHatch)
Screw the abs. The abs pump runs to much now. When you start it up the pump will just keep kicking in for a couple minutes. So I just want a master cylinder for a 91 Si?
H-T White Ops
For 5th gen:
- 94-95 USDM 2DR EX ABS (rear disk)
- 92-95 USDM 4DR EX ABS (rear disk)
- 94-95 USDM 4DR LX ABS (rear disk)
- 92-93, 95 USDM 3DR Si (rear disk)
- 94 USDM 3DR Si ABS (rear disk)
All others not mentioned have rear drum and no ABS.
'96-'00 LXes don't come with stock rear disk.
For 6th gen:
- 96-00 USDM 2DR EX ABS (rear drum)
- 98-00 USDM 4DR GX ABS (rear drum)
- 96 USDM 4DR LX ABS (rear drum)
- 99-00 USDM 2DR Si (rear disk, non-ABS)
- 99-00 Canadian 2DR SiR (rear disk, ABS)
For 5th gen:
For 6th gen:
Re: (kaiba)
sorry about that, i got a 94 civic 4dr and it has rear drums, i didnt know that rear discs were an oiption for those years. i thought only ex's
Re: (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">but then again an integra rear swap is so easy its stupid
AND you get a rear sway bar which cvics never came with </TD></TR></TABLE>
The 92-95 EX ABS came with rear swaybar but a little smaller. And also the 99-00 si did too.
Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">The 92-95 EX ABS came with rear swaybar but a little smaller. And also the 99-00 si did too.</TD></TR></TABLE>
from what i heard the ek swaps were totally diffrent than eg swaps, this is an EG convo
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Best master cylinder upgrade would be a <FONT SIZE="4">91 Civic Si 15/16 master cylinder.</FONT> There are 1 inch Integra master cylinders available, but there is no measureable gain between the 15/16 and a 1 inch. And it's more work while the 15/16 is a bolt-on replacement.
I don't know how that will affect your abs though. In fact, even changing to stickier tires and bigger rims can affect the abs...</TD></TR></TABLE>
No. 1991 Si is till the crappy 13/16ths. You mean 1991 EX 4 door - it's 15/16ths. And since his car has ABS the hard line closest to the booster will NOT work because ABS fittings are bigger than non-ABS, so the 1991 anything will not work.
...but O.P check your current master cylinder and make sure it's not already a 7/8th unit - if it is 7/8 a 15/16ths isn't much of an "upgrade" at all. If I recall the ABS cars already have the bigger 7/8ths unit. If you really want an upgrade and don't mind the extra effort try a 94-95 Integra LS/GS/GS-R ABS booster and master cylinder. Again it might not make much, if any, difference in braking though.
