Info needed on relocating battery to front bumper? 92-95! Example pic inside!!
Is there a kit you can buy to achieve this or custom fab?
Thanks for any info
Thanks for any info
Re: Info needed on relocating battery to front bumper? 92-95! Example pic inside!! (Hybrid93Hatch)
Don't do it. Not only is it retarded, you might mess up the car in the rain.
Are sealed batteries water resistant? I don't plan to drive the car in the rain (it's not a daily driver). I's rather have the weight up front then in the back. I could most likely fab up an enclosure to keep it from getting wet.
Darth ModerVader
I can't think of a single benefit to putting the battery in that spot. Either leave it in the stock location, or move it towards the rear (though try not to place it too far behind the rear wheels).
Ek Forever y0!
Re: Info needed on relocating battery to front bumper? 92-95! Example pic inside!! (SleeeeepyDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeeeepyDX »</TD></TR><TR><TD CLASS="quote">Wouldn't the rain expletive it up?</TD></TR></TABLE>
Um, water + battery connectors = corrosion
Chrsit on a crutch.
Chrsit on a crutch.
Re: (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR »</TD></TR><TR><TD CLASS="quote">WHY?</TD></TR></TABLE>
Cleaner bay / more weight in the front. Maybe the dash will be a better option
Anyone have pics of the battery relocated to the dash?
If your going to relocated it put it in the trunk.
In the dash? I think this against every regualtion at every track. I guess if you never go to the track it wouldnt b=matter but then again moving the weight around would only matter if you raced so...
Re: (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 »</TD></TR><TR><TD CLASS="quote">If your going to relocated it put it in the trunk.
In the dash? I think this against every regualtion at every track. I guess if you never go to the track it wouldnt b=matter but then again moving the weight around would only matter if you raced so...</TD></TR></TABLE>
Well damn. Maybe I should get a smaller battery, leave it in the OEM location, make it look good, and call it a day
This car will be tracked for pleasure, damn sure not building it to hard park
Re: Info needed on relocating battery to front bumper? 92-95! Example pic inside!! (papa_jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa_jon »</TD></TR><TR><TD CLASS="quote">just wonding .. why not put it to far behind the rear wheels...?</TD></TR></TABLE>
The car will be gutted / painted & cleared on the inside and don't care to have the battery in plain view.
Tony1 here on H-T makes custom brackets like that. Doing it like this is more of a drag only type deal because it puts more weight on the front which could help with wheel hop. Putting the batt. in the back will balance out the weight (although corner weighing is the only way to really know if your good or not). Dont put the batt. in the dash, if you need a jump what are you going to do? Is this a street car or a track only car?
The more weight you put behind the rear wheels, the more momentum will be traveling outward during hard cornering.
Do this: Take a baseball bat and swing it as hard as you can like you're going to hit a ball with it. Do that once or twice. Then take a 5 pound weight and connect it and swing the bat again. Feel the difference. It will feel as it the bat wants to pull itself from your hands. Same concept
Darth ModerVader
Basically, the more mass you have located far from the vehicle's center (or "pole"), the greater the negative impact it will have on handling.
It's also one of the reasons why having the battery in the location shown above is a poor idea.
Ek Forever y0!
Re: Info needed on relocating battery to front bumper? 92-95! Example pic inside!! (Padawan)
You could also get one of those smaller batteries and mount it in the spare tire well.
That's what i'd do.
But I really don't see the problem with leaving it in it's stock position, most track officially prefer it there with the stock bracket.
You can make it look clean, just get some jdm tie downs or something.
That's what i'd do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Tony1 here on H-T makes custom brackets like that. Doing it like this is more of a drag only type deal because it puts more weight on the front which could help with wheel hop. </TD></TR></TABLE>
I'm going to contact this member
Yeah, traction sucks!!
I've had the car up and running from Sept.15 until middle of December. The car saw no rain
Anyone else with info on the bumper trays would be helpful
hey can you give me a jump?
just give me a few minutes to remove MY FRIGGIN BUMPER
but maybe it was done more for security reasons? back up for alarm? who knows......
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">hey can you give me a jump?
You dont need the battery if your going for a jump start. Put red cable on the batt post of the starter. Put the ground anywhere on the body. Jump car and the alt should do the rest. Now if the alt is dead then yea not much you could do but take off the bumper and take the battery to get replaced and checked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuster_Cluck »</TD></TR><TR><TD CLASS="quote">
He does not carry this product Time to fabricate
just give me a few minutes to remove MY FRIGGIN BUMPER</TD></TR></TABLE>
I can't even remember the last time I needed a jump. May have been someone else in need of a jump....It's been at least 8-10 years
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">but maybe it was done more for security reasons? back up for alarm? who knows......</TD></TR></TABLE>
More weight on front end & cleaner engine bay
Hopefully SummitRacing has the Odyssey tray on display so I can get some pics / dimensions to make this piece
Si_Allen
08-15-2002 10:43 AM
