civic 96 burning oil and white smoke
hi
I need you guys help on this, my 96 civic dx engine was burnning some black smoke and some time white smoke....umm....At first i think it was the head gasket but after i change to a new one it still do the same....so u guy out there have any idea whats wrong with my engine just tell me thanks
Re: civic 96 burning oil and white smoke (skyvang2)
maybe your valve seats or piston rings going bad. i think black smoke is fuel, maybe running rich. how does the car run?
Re: civic 96 burning oil and white smoke (JDMH22HondaPrelude)
the car running pretty good..just black smoke and white smoke whenever start I from 0- whatever speed...
Ek Forever y0!
ROFL, every post in here except mine has a n00b avatar.
How appropriate for the posters.
So much misinformation so little time.
» Search Results
Your search for smoke returned 981 results.
» Search Results
Re: civic 96 burning oil and white smoke (Mr.EM1_EK)
White smoke: White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. The white smoke is steam. There are special gaskets (head gaskets are the primary gaskets) that keep the antifreeze from entering the cylinder area. The cylinder is where the fuel and air mixture are being compressed and burned. Any amount of antifreeze that enters this area will produce a white steam that will be present at the tailpipe area.
If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the under side of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze, as serious internal engine damage can result.
How did antifreeze get in the oil or cylinder in the first place? The engine probably overheated and a head gasket failed due to excessive heat, thus allowing antifreeze to enter the cylinder (Where it is not meant to be).
Ek Forever y0!
Re: civic 96 burning oil and white smoke (luvmysi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmysi »</TD></TR><TR><TD CLASS="quote">or cracked head
Which allows coolant in the engine.
SpOoN_EM-1
07-21-2005 02:56 PM
