VERY small leak in factory steel brake line - what should I do?
I just discovered a "pinhole" leak on one of my steel brake lines that go from the proportioning valve to the rear right brake cylinder. The leak is a few inches away from the proportioning valve and if I have someone press on the brakes I can see a very faint stream of brake fluid...
So what should I do? Can I just sandpaper it down and solder the pinhole or do I have to absolutely get a whole new line?
Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic »</TD></TR><TR><TD CLASS="quote">best just to buy a new line...not worth the gamble imo</TD></TR></TABLE>
The best thing you could ! Why risk having brake failure ( if possible ) and putting your life and other's in danger ?
Re: (Heretic:Si)
replace there cheap and u can get them already bent online.. ill find the page i was just looking at brake lines for my sol cause i took out the abs cause it didnt work
heres the site.. hondapartscheap.com
Re: (del_slow420)
Thanks everyone! I will get the brand new line then and be done with it - besides its a pain in the butt to work on those brake lines with the H22A IN the car (it's currently out) so I might as well get it done right.
Re: (pcguy760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 »</TD></TR><TR><TD CLASS="quote">Hey man - majestichonda is cheaper </TD></TR></TABLE>
That is where I get all of my OEM parts. Good service.
DB2-R81
10
06-30-2003 09:27 PM
