NEED HELP ASAP
NEED HELP ASAP
ok so i have a 97 Ek i swapped in a 00 Si B16, i used a 98 Ex wire harness... i did the swap a while ago the only thing i did was not hook up the CKP sensor because i was running a JDM Type R ECU but now i need a smog so im running a p30 ECU and now i need to wire up my Secondary O2 which is no prblem But my CKP sensor the motor has a 2 wire and my harness is a 3 wire how do i hook it up what do i need to splice...? thanks in advance i really need help ASAP...
Re: (95civickid)
CKP (Code 4) is in the Dist. If your throwing that your dist. needs a rebuild. CKF (Code 54) is near the oil pump which i believe your talking about. The 3rd wire is a ground. You could match up the wires and be fine.
https://honda-tech.com/zerothread?id=1196153
Not sure if that helps but try using the search button and entering what your looking for...
well thanks ^ but i already know how to wire the O2 sensor im trying to figure out the 2 wire and 3 wire crank postion sensor and he used OBD2b with OBD2b im using an OBD2a wire harness with an OBD2b Block... any one can help
Re: (95civickid)
Take your plug from your old engine, cut the plug from the new engine, put the 2 wires that go in the same location (minus middle dont use) and connect it all together, seriously not hard. Yes very long on i know
