Strut bars?
Strut bars?
I wasnt sure where to put this so here it is.
I got a set of strut bars cheap enough for me to buy them. There are used so no instructions, doh. Here is a pic, can someone tell me where/how to install them correctly? Thanks
Re: Strut bars? (iceman7329)
uhh...?
alright well if you just look at the top of your suspension (where it mounts to the shock tower) you will see there are two nuts...undo them, put the strut bars over the studs, then fasten the nuts ontop of them... As for the c pillar bar, if thats what it is, then undo the bolt keeping your seatbelt like top point onto ur car, and then put the cpillar bar moutn there and use that bolt. IF its a lower tie bar put it in between where ur rear lower lcas go to ur frame.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 »</TD></TR><TR><TD CLASS="quote">I wasnt sure where to put this so here it is.
this one looks like it goes to rear bottom
this one rear in trunk
and this one is front tower check the measurments also
correct me if im wrong
In the first picture, the top one is the rear upper strut, 2nd is the front upper strut, last is the rear lower tie (most likely).
To install them, remove bolts, put on bar, put bolts back on @ specified torque specs for those bolts.
HT White Ops
Re: Strut bars? (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 »</TD></TR><TR><TD CLASS="quote"> correct me if im wrong </TD></TR></TABLE>
You are.
Rear lower tie bar (worthless)
Front Strut Bar
Rear Strut Bar
You are.
Front Strut Bar
Rear Strut Bar
Re: (dao_yaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dao_yaj »</TD></TR><TR><TD CLASS="quote">if you look at the dtrut, you will see where they go
Good, kinda what I figured.
Re: (amej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 »</TD></TR><TR><TD CLASS="quote">You'll have to cut into the plastic or the carpet (whatever is covering the shock tower) and it will be exactly like installing a front upper strut bar.</TD></TR></TABLE>
So it will run through the inside of the trunk correct?
Re: (iceman7329)
So it will run through the inside of the trunk correct?</TD></TR></TABLE>
Yes. But it will run above the floor, probably 4-6 inches so if it's a grocery getter or you have a lot of things in the trunk, be prepared to have that bar in the way. It doesn't sit all the way towards the seat either.
I tried to put my new rear strut tower bar on and it wouldn't fit. I was pissed. Then I figured out to jack the back up so the wheels are off the ground and it fit like a charm. Might be the same for the front too.?...
Re: (amej8)
Yes. But it will run above the floor, probably 4-6 inches so if it's a grocery getter or you have a lot of things in the trunk, be prepared to have that bar in the way. It doesn't sit all the way towards the seat either.</TD></TR></TABLE>
Ok, my subs are in the way. Its time to build a box flush in the floor where the spare should go anyways.
Thanks guys.
Thanks guys.
Re: Strut bars? (4EN[sic])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4EN[sic »</TD></TR><TR><TD CLASS="quote">]I tried to put my new rear strut tower bar on and it wouldn't fit. I was pissed. Then I figured out to jack the back up so the wheels are off the ground and it fit like a charm. Might be the same for the front too.?... </TD></TR></TABLE>
Yep, probably going to be the same for the front.
kenjief8
12-30-2004 06:59 AM
