d16y8 question
d16y8 question
Well I'm installing some aftermarket gauges, oil psi and water temp..
My question is what is the bolt to the left of the oil filter? Can I plug my oil gauge into this? If you guys don't know what bolt im talking about I can probably take a picture.
Re: d16y8 question (EJ8 Kenobi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi »</TD></TR><TR><TD CLASS="quote">It might be above the filter but Its to the left</TD></TR></TABLE>
It's your oil pressure sensor, and yes its where your wire goes for your gauge.
Re: d16y8 question (1995Civic)
I thought the sensor had a plug and wire on it? or , was I reading that info for a B series? This looks like a large bolt.
Nice avatar lol
Nice avatar lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi »</TD></TR><TR><TD CLASS="quote">I thought the sensor had a plug and wire on it? or , was I reading that info for a B series? This looks like a large bolt.
Nice avatar lol</TD></TR></TABLE>
http://www.theoldone.com/articles/oilpressure/
Everything you need to know on this topic
...thank you, i like my avatar
Thanks man, I'm gonna give that a go today and let you guys know how it turns out.
Any places on the block or head I can install the water temp probe besides the stock location?
Well I'm not sure what that bolt was. I found the sensor just right above the filter. Now the question is, how do I remove it? Feels like a rubber shield tightly seals it.
I've spent the last week getting the front end installed so I pushed this project to the side, but I took some pictures with my phone.
so how do i remove the sensor?
the sensor should just pull out, mine did. and leaving the sensor to the side is ok, that wont throw any cel.
Re: d16y8 question (1dumbassscreenname)
the rusty bolt is a water drain plug ... to drain water from the block
the oil pressure switch plug pulls off....
it's a little hard to do, but it will just pull off
grab it really tight on the skinny part (or use some pliers)
Just dont rip the wire out of the plug
nuttybumpo
05-30-2007 04:18 PM
JamesQ
10-07-2004 03:59 AM
