95 gsr head into 93 gsr
can you swap this heads because he 93 teggy gsr motor is 1.7 and people say is more like the b16 so should i swap the b18 head or b16 or keep stock. also what tranny is good for the 93 B17A gsr
correct me if im wrong someone. but i pretty sure that b series heads are interchangable with each other, and i think that the gsr still has the same tranny which personally i think is a pretty good tranny. b16 tranny is shorter. but if you really want to get complicated go with b16 1,2 gsr 3,4 ls 5
GDD's Dr. Phil?
Re: (ELSUICIDA)
People build CRVTEC's with that head, I would make the uneducated assumption that there should be absolutely no problem, and if there was any issue at all, I also would assume that they would be easily resolved, but remember if I assume I make an ***-outof-U-and-ME HEHE
GDD's Dr. Phil?
Re: (ELSUICIDA)
whoa buddy no one said that, first off its a different rotating assembly than both ITR and CTR, not to mention different bore. It will be a full build either way, so consider more options among those if you are within a budget. by the way im partial to gsr tranny
GDD's Dr. Phil?
Re: (ELSUICIDA)
some people hate them, i have seen many running very strong and nice (then again alot of people hate h22 also). That seems like a fair price for anything dohc vtec with under 100k, did it come with a head? intake manifold? sheet metal? ecu? wiring? trans? wait... even better, what exactly did it come with?
been there done that
Re: (ELSUICIDA)
keep your stock head on there. you dont gain a whole lot from swapping on a p72 head. and no the bore is not different than a b17/b18.
b17's are rare engines cause they were only in 92-93 gsr's. anyway you decide to build it you'll get similar results as a b16.
Re: (doood)
ok i have "oneludesol" tell me is different bores which i doubt it because is a b series block and they all have same bores just diffrent pistons,rods etc, and one saying is the same, im gonna go with "doood" is the same bore.
GDD's Dr. Phil?
Re: (ELSUICIDA)
dood is right all but b20 sorry (I always thought b17 was "black sheep" status like the b20 in the preludes)
Modified by oneludesol at 5:03 PM 5/5/2007
Re: (Danronian)
heres what i would do in this situation.buy the gsr head and build it then slap it on no down time.if you have the money or can save up find u an ls block and do the same.
hth
hth
