IM TRYING TO GO ALL MOTOR
I need to know what to do next to my car. I have a 2000 Si. I want to go into Circuit racing, and i need to know what mods i need for my motor. Right now i have AEM cold air and Megan 4-1 headers, but i need everyones suggestions on what to do next
Re: IM TRYING TO GO ALL MOTOR (Devious951)
I was thinking about boring my block to fit the Civic Type R Pistons ans pot and polishing my head.
Ditch The Megan header get some RMF-or Smsp-or AN-r.com
Aggressive cams, High compression Pistons, Hondata or Crome Extra tuning
And for Circut You got to get a pro Suspension
crower makes excellent cams stage 1-3 i know you won't need a stage 3 that's kinda crazy but a stage 2 should open up about 15 hp (correct me if i'm wrong) those will run you around $400 shipped if you look around
you'll have to choose the comp of the pistons you want... srp makes good pistons... je makes excellent pistons as well i believe you can get je pistons with eagle rods for about $800 shipped they are availible in 8.0, 9.0, 9.8, 10.7, 11.5, 12.2 compressions
a port and polish would be nice... some valve work also
again correct me if i'm wrong on any of this guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devious951 »</TD></TR><TR><TD CLASS="quote">I was thinking about boring my block to fit the Civic Type R Pistons ans pot and polishing my head. </TD></TR></TABLE>
shoudln't be alot of boreing since they are both 81mm
Re: IM TRYING TO GO ALL MOTOR (jeffsciv23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devious951 »</TD></TR><TR><TD CLASS="quote">I need to know what to do next to my car. I have a 2000 Si. I want to go into Circuit racing, and i need to know what mods i need for my motor. Right now i have AEM cold air and Megan 4-1 headers, but i need everyones suggestions on what to do next </TD></TR></TABLE>
How many do you have? Get a few more, the power goes up exponentially.
When you say circuit racing. Do you mean you want to compete in Honda-Challenge. If so look at the rule book first.
INTAKE:
better CAI (a 3" one)
larger bore TB(I'd say 65mm is good)
IM (the edelbrocks are good, but if you can find one the cnc ported ITRs are better)
-portmatch everything
HEAD:
-cams, I'm assuming that you're wanting to go out on a road coarse like button willow or willow springs, in that case the cam with an excellent overall curve is the Buddy club spec III+
-valvetrain of course(go with flat vlave for a little more compresion)
-PORT/POLISH WORK
-ARP hardware(just to be safe
EXHAUST:
-as already said, ditch that cheap *** HEADER (not plural!) and get a good one (like rage smap, hytech, profab, etc.)
-also get a good custom 2.5" madrel exhaust
BLOCK:
-first off I'd stay away from CTR pistons, there are problems with them because of such a peaky dome. If you want to stay with an OEM piston go with the ITR
-Balance and BP everything
-ARP hardware
TRANNY
-Higher final drive
-LSD
-better clutch
-lighter flywheel
that's about it to get the most out of you're motor without going too crazy(like a big bore/stroker kit). I didn't list them but if you can find them relatively cheap I'd get a B17 crank and rods(the slightly longer stroke is supposedly good for about 5-7whp and 4-5ft/lbs all the way through the powerband)
as for cost, that depends purely on the parts you buy, the labor you can do yourself(if any) and the severity of the machine work I'd say for all that listed above expect to spend at least 3K
INTAKE:
HEAD:
-PORT/POLISH WORK
EXHAUST:
BLOCK:
-ARP hardware
TRANNY
-Higher final drive
-LSD
-better clutch
-lighter flywheel
Re: (jeffsciv23)
Well what how much hp can i get from all motor. And i was thinking about a stroker kit. Would that be a good d ecision?
Re: (Devious951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devious951 »</TD></TR><TR><TD CLASS="quote">Well what how much hp can i get from all motor. And i was thinking about a stroker kit. Would that be a good d ecision?</TD></TR></TABLE>
that really depends on how much money ou can drop in the build, a setup like I mentioned would probally get around 190-205whp
if you go with a bigger bore, higher comp. piston as well as a longer stroke and aggressive cam and you' be looking at 230+whp...just go through the "all motor" forum search, and you should be able to get some kind of idea on what is realistic...if you plkan on shooting for something ridiculous like 300whp on stock bore and spending under 4000, you might as well forget it and go turbo
ek9tl
05-27-2006 06:42 PM
Allstar
01-20-2003 09:15 AM
