Coolant and vacuum hose diagram?
i just finished putting my d15b vtec back into my car (95 ex coupe) and i'm having trouble with the coolant and heater hoses i guess i have some things mixed up becuz it is overheating fairly quikly. I was wondering if anyone had a diagram of all the hoses. the haynes manual dosn't really give you a defined diagram of them all. Thanks
Re: Coolant and vacuum hose diagram? (bycrida)
Well Heater hoses aside cause you should be able to figure out where those go theres only two places one for each hose. but does the vehicle run fine but overheat? cause if you had any of the vac\coolant lines mixed it would run like **** due to the coolant going into the combustion chamber. so if it does run fine then I would be looking at actual problems (radiator, water pump, thermostat) if it dosent run fine then I can only imagine that right around the throttle body is where you got them mixed up so just remamber that the one that goes to the intake is also the pcv or valve cover tube that releases crank pressure the other is throttle body cooler lines which will either just go through a couple fittings on bottom of tb or go the the cold bypass valve on bottom of tb.
thexbrothers
09-29-2013 03:45 AM
2000vsm
08-25-2003 07:14 PM
