Hondata Intake Manifold Gasket and FIA - D16Y8 >>
Old 05-17-2008, 06:35 PM
platinum00's Avatar
Default Hondata Intake Manifold Gasket and FIA - D16Y8 >>
For a Hondata intake manifold gasket on a D16Y8, what do you do with the FIA (Fuel Injection Air) holes on the manifold? The gasket does not allow the head to mate with manifold.
I was just going to remove the FIA system since I dont see a use for it on a OBDI setup. Can I just plug the holes in the manifold, cap the port on top of manifold, and remove the FIA control value?
-platinum.
Old 05-17-2008, 09:08 PM
Blk00EJ8's Avatar
Default Re: Hondata Intake Manifold Gasket and FIA - D16Y8 >> (platinum00)
The air injection holes can be plugged by any means you see fit... steel epoxy, jb weld, etc. I believe even running an OBD2 ECU you can do it without negative consequences.
On another note, I thought Hondata came out with a revised gasket to compensate for the air injection holes, but I could be wrong. The older gasket that was advertised through 2000 was later modified to "through '98 models." I think the newer one is up to 2000 since older D16s with no air injection won't be adversely affected by the extra gasket material.
Old 05-18-2008, 05:29 AM
platinum00's Avatar
Default Re: Hondata Intake Manifold Gasket and FIA - D16Y8 >> (Blk00EJ8)
Thanks for the reply... interesting note about the newer hondata gaskets. The one i have does not have the air injection holes. Maybe i got one of the "older" ones.
Either way if the FIA system can be removed on a 00 running OBDI then its coming off.
thanks
-platinum
Old 05-18-2008, 06:16 AM
sicones's Avatar
You have to plug each of the 4 little holes above each injector, putting a cap on the vacuum nipple will have no effect. There may be an adverse effect IF you use the stock 99-00 ECU. The engine may not idle correctly (or high enough) on cold start ups. I would get the right gasket.
Old 05-18-2008, 08:18 AM
platinum00's Avatar
Default Re: Hondata Intake Manifold Gasket and FIA - D16Y8 >> (sicones)
Not running a stock ecu. Hondata OBDI S300.
I plugged the holes on the performer-x with some 4mm screws and a small amount of JB-Weld. If I have problems with idle, I should be able to adjust the IAC with the S300. I will let you know if I have any problems but not anticipating any since pre-98' did not have an FIA anyway.
-platinum
Old 05-18-2008, 02:07 PM
sicones's Avatar
It doesn't matter then. What are you going to do about OBD2 emissions?
Old 05-19-2008, 04:16 AM
platinum00's Avatar
Runinng OBDI, so none of the OBDII stuff works.
-platinum
Old 05-19-2008, 07:44 AM
Blk00EJ8's Avatar
I think he's referring to inspections. Not sure if OH does that sort of thing, but both NJ and NY are pretty strict when it comes to inspections regulations.
Old 05-19-2008, 10:20 AM
platinum00's Avatar
oh yea... we are lucky here. No checks yet but it's not a steet car anyway.
-platinum
fake mugen power
07-25-2019 05:42 PM
949
04-07-2009 08:04 AM
huevosrancheros
10-14-2006 09:33 AM
egturbo
09-17-2004 07:54 PM
Mike95lude
11-22-2003 01:20 PM
Quick Reply: Hondata Intake Manifold Gasket and FIA - D16Y8 >>
