Drive Belts Squeaking???
Old 05-18-2008, 05:38 PM
prues32's Avatar
Default Drive Belts Squeaking???
My belts beganing to squeal and I was told I could just tighten them to solve the noise could anyone help me out on how to do this? Thanks...
Old 05-18-2008, 05:47 PM
* B A N N E D *
aquabob89's Avatar
Default Re: Drive Belts Squeaking??? (prues32)
Figure out which belt squeaks.
Replace it.
But, if its the alternator belt theres an adjustment bolt.
Same with the A/C just find it its obvious it will be a bolt that has a place to be adjusted.
Same goes for the Powersteering belt i think.
Old 05-18-2008, 05:58 PM
VTEC_Viking's Avatar
Could also be the idler pulley, sometimes they need to be regreased.
Get a Haynes manual and you should be all set. You just loosen the bolt, slide it a tiny bit forward check to see if the belt is looser than 1/4 of an inch, if not tighten down should be no more squeak.
Fo-Do Fanatic
04-07-2010 03:59 AM
jmoore2112
Honda Civic (2001 - 2005)
05-30-2008 11:40 AM
Prudz_lude
06-17-2007 03:51 PM
lude1888
06-06-2007 09:26 PM
EVIL Hx Coupe
05-22-2002 02:19 PM
Quick Reply: Drive Belts Squeaking???
