RADIATOR help
RADIATOR help
i having problem wit my coolant backing up into the overflow tank and i have to add more coolant into my radiator every day and i replace the head gasket new water pump new radiator new thermostat and new hoes and i try using preston strong leak and still doing the same thing backing up into the overflow n runnin out of coolant
Modified by civicsir94 at 4:28 PM 5/19/2008
Re: RADIATOR help (civicsir94)
So you're saying there's no coolant in your radiator, and it's all going into your overflow?
Get a new radiator (or borrow a friend's to test). radiatorbarn is your friend.
Spend the $5 on a radiator cap. The cap controls the pressure. If you have no pressure in the cooling system when it gets hot the expanded coolant (from the heat) will go to the over flow bottle and overfill it spilling it onto the ground. Now as the motor cools there is less coolant (because you've spilled some) to return to the radiator and so the car will get hot. Good luck.
crxaddikt
03-25-2014 11:00 PM
