Battery or wiring problem?
Well sometimes when I turn off the car I see a slight dim of light on my gauges.. you know the usual brightness you see on your cluster when you start the car at night therefore you can read you guages.. then I start the car again and then turn it off and then it goes away.. sometimes when I dont check I park and come back, I cant start my car.. the battery drained. Im guessin its because of that.. what is wrong wit my car?
Re: Battery or wiring problem? (raidacaipo)
i would start checking grounds first of all.
if you try to start it and it doesn't crank then specifically check your transmission ground.
Re: Battery or wiring problem? (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks »</TD></TR><TR><TD CLASS="quote">i would start checking grounds first of all.
if you try to start it and it doesn't crank then specifically check your transmission ground.</TD></TR></TABLE>
it does start and thats the problem.. it runs fine and everything
