compression test
Old 06-05-2008, 11:42 PM
obuhmyuh's Avatar
Default compression test
did a compression test after fixing my timing: https://honda-tech.com/zero...14308 . and I got (1)140-(2)180-(3)180-(4)180. The test was done at operating temp but i forgot to do it at WOT , will retest it tomorrow, but that cyl #1 is off by a lot, im guessing a have a bent valve? I searched but I couldn't come up with anything solid... any more insight would be great. And for some reason my adapter from my tester got stuck in the spark plug hole.
JDM d15b SOHC VTEC (w/d16z6 camshaft)
Old 06-06-2008, 06:38 AM
wmac's Avatar
try putting a little oil in cyl-1 to see if that brings up the comp. if so its rings, if not then it's the head.
Old 06-06-2008, 10:15 AM
obuhmyuh's Avatar
Default Re: (wmac)
k im gonna check my valve clearances for cyl #1 as well... I doubt it's my piston rings because, i started having issues when my timing was off by a lot, so im guessing a piston bumped into a valve, bending it, causing shitty compression.
im gonna take my old z6 head into a performance shop and have them service the valves on it and maybe mill it down a tad. Is it okay to drive around with a bent valve for a little while???
Old 06-06-2008, 10:54 AM
2004es2's Avatar
Default Re: (obuhmyuh)
Yeah you can drive with a burnt valve but a bent one can be dangerous to your pistons if it does break and drop into the cylinder then its bye bye to the pistons. Do a leakdown test if possible and you should be able to tell the problem by listening if air is escaping from the im/ exhaust manifold or if it is leaking into an adjacent cylinder. It is way more accurate than a compression test.
Old 06-06-2008, 11:31 AM
obuhmyuh's Avatar
Default Re: compression test (obuhmyuh)
i adjusted my valves and the car SOUNDED better, i was letting it warm up and i was holding the rpms at like 2-3k, and it just shut off again (had this problem before thus the head rebuilding), and my timing jumped AGAIN and my spare cam gear broke and now im down to zero! wtf, im gonna start a new thread for this prob. now...
Old 06-06-2008, 11:37 AM
obuhmyuh's Avatar
https://honda-tech.com/zeropost?cmd=fshow&id=1
civic-one
04-06-2011 08:02 AM
Smash03
08-24-2008 11:21 PM
Cheez-It
10-02-2007 07:27 PM
slowassciv33
11-20-2006 08:25 PM
EF8_SiR
07-20-2003 10:24 PM
Quick Reply: compression test
