h22 to f22 swap?
h22 to f22 swap?
ok so i have a 93 civic with a h22a4 and the motor is blown, i just bought a 94 f22b1 sohc vtec and am goin to swap it into the civic, i already know that my motor mounts, tranny, clutch/flywheel can be swapped from the h22 to the f22. what i dont know is if the wiring is goin to be the same, am pretty sure a lot of it will work. does anyone know anything about this swap.. thnks
Re: h22 to f22 swap?
there is another two wires at the ecu that has to be swapped back. when the h22a was installed they were swapped.
i forget which ones they were of course but i learned this the hard way when i had a h22 in my accord that i put back to f22 to sell and i ended up selling it with a CEL because i didnt swap the two wires.
What 2 wires?? I havn't had to swap any wires at the ecu when swapping an H22 into a civic??
the H22 and the F22 dont use the same mounts.. how ever why are you swaping an Fseries in a civic? it doesnt make sence to me.. what harness are you using the H22 or F22?
the f22 and h22 are the same mounts, i did this same "swap back" about 9 years ago when my H22 spun a bearing. i used my same wire harness as i used for the H. i never had a problem at all except the fact the F22 sucked *****.
ah..i got goofed..OP said f22B not f22A. carry on
matix
09-25-2003 06:18 AM
