check engine code?
Old Jun 8, 2008 | 07:21 AM
Vt3c_eg's Avatar
Default check engine code?
okay.im confuse when i jumped the two wires together and turn my key to on the check engine turns on. it blinks 7 times fast and the 2 times slow and once fast again. im not sure what the coed is. does that mean i have 2 problems or just one! help me put!
n yes i checked the thread for check engine just that im confuse of what its throwing out to me.
Old Jun 8, 2008 | 09:46 AM
Burnt Toast's Avatar
Default Re: check engine code? (Vt3c_eg)
Two problems. First is code seven (TPS - throttle position sensor). Second is code 21 (VTEC spool solenoid valve)
Old Jun 8, 2008 | 01:18 PM
Vt3c_eg's Avatar
Default Re: check engine code? (Burnt Toast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burnt Toast &raquo;</TD></TR><TR><TD CLASS="quote">Two problems. First is code seven (TPS - throttle position sensor). Second is code 21 (VTEC spool solenoid valve)</TD></TR></TABLE>
thanks! thats what i tought it was too. how do i fix the spool spolenoid valve?
Old Jun 8, 2008 | 04:26 PM
No clue, but make sure its still plugged into your harness.
Use the search link in red at the top right. Make sure you check in the archives.
Old Jun 9, 2008 | 04:40 AM
Vt3c_eg's Avatar
thanks! anyone else know how to fix it? i search but nothing.
Old Jun 9, 2008 | 04:53 AM
Vt3c_eg's Avatar
never mind found info!
Old Jun 9, 2008 | 06:40 AM
h22aBB4's Avatar
lol how to fix it? thats like asking "my car is broken, how do i fix it?" you need to know whats wrong with it before you can fix it
Old Jun 11, 2008 | 04:37 AM
Vt3c_eg's Avatar
Default Re: (h22aBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22aBB4 &raquo;</TD></TR><TR><TD CLASS="quote">lol how to fix it? thats like asking "my car is broken, how do i fix it?" you need to know whats wrong with it before you can fix it</TD></TR></TABLE>
what dumb ***! i just gave you the check engine code! what a dumb ***. dont post if you aint got **** to say!
asocallocal
Jun 6, 2010 11:30 AM
gsr2envy
Nov 7, 2004 03:32 PM
9WON4
Apr 22, 2004 05:38 PM
turbojdm521
Jun 15, 2003 09:57 AM
YTYPER
Jun 30, 2002 09:01 PM
