Something NOT Good WTF?
okay guys i have a weird question, i dont know why but sometimes when i drive my car starts jerking real hard when i throw it into gear and release the clutch. and it only does it sometimes what could be the problem? and why does the gas pedal get hard at the beginning when i try to gas, its real weird and then its regular till i come to a stop it would happen again, now again. it doesnt happend all the time... any ideas?
Re: Something NOT Good WTF? (vsmhatched)
throttle cable issues?, is it stock or swapped? for ur jerking issue are you letting the clutch out too fast/not giving it enough gas? that will cause it to violently jerk
Re: Something NOT Good WTF? (H22Ej1)
well it swapped to a b16, na the jerking only happens sometimes. all of this happens all at once, any idea why the gas pedal gets harden?
Re: Something NOT Good WTF? (ThatOneOG)
the problem with your gas pedal is buildup in your throttle body, take your intake off and clean your throttle body, be sure to open the butterfly valve and clean where it sits against the body itself. That should do the trick
