A/C Issues
A/C Issues
my hatch never came with AC so i installed everything got it working but the fan never kicks on i tested it and it works also the the line going from the condeser to the evap can and from compressor to the condenser get hot and its not just warm its really hot
any ideas
the system works fine when im moving but when i stop or sit still there is no AC at all
any ideas
Re: A/C Issues (Fullthrottle297)
Did you hook up a manifold gauge to the high and low pressure side fittings? You will need to do this to diagnose your system pressures.
Was the A/C system you put in new or used? If used, there could be blockage in the line somewhere.
Check the FAQ section. There's a great write up on A/C that should help you out. You can also download a helm pdf manual if you haven't already.
Re: (jadziasman)
the system is used and i havent diagnosed yet so it could be possible that its clogged
going to diagnose will post up results
Modified by Fullthrottle297 at 4:09 PM 6/8/2008
