do i Need a Proportion Valve of I want to upgrade from Drums breaks to Disk Breaks ??? Need Help
Old 07-06-2008, 12:48 PM
dj theoretic's Avatar
Default do i Need a Proportion Valve of I want to upgrade from Drums breaks to Disk Breaks ??? Need Help
Let me know if this is needed. I heard so many things. just want to know the straight up answer??? help anyone Please !!
Old 07-06-2008, 01:09 PM
BlueIntegraBoy's Avatar
Default Re: do i Need a Proportion Valve of I want to upgrade from Drums breaks to Disk Breaks ??? Need Help
I ran without a 4040 prop valve with just my rear disk conversion without any problems. Braked fine and didn't lock up at all.
Old 07-06-2008, 01:55 PM
Seagull Management
94EG8's Avatar
Same here, i never changed mine, actually i went to honda and compared part numbers between my Sedan Canadian LX (US DX i believe) and the part number for my my prop valve is the same as a '92 Si hatch with rear discs, so i'm really not convinced there even is a difference.
Old 07-06-2008, 02:00 PM
pepsiDX20's Avatar
I have full gsr brakes on my DX coupe. I did NOT switch the prop valve or m/c, booster and it works fine. just make sure that you bleed everything properly.
Old 07-06-2008, 02:05 PM
CIVICTUNER04's Avatar
i did the rear disk conversion on my del sol and now my breaks are all kinds of mushy and doesn't wanna stop. i have bleed them prob. 2 dozen times. they have new rotors(cross drilled and slotted) , new pads and m.c going on tom or tues. does any one think that because i have my vaccum manifold coming off that line that its messing up my breaks???? it is before the check valve any oppinion greatly appreciated
Old 07-06-2008, 02:06 PM
riceburnerryan's Avatar
when i did my rear discs i didnt switch my prop valve, but i did get the GSR master cylinder and brake booster... it worked fine, like the guy above me said, just make sure you bleed
Old 07-06-2008, 02:13 PM
OMGWTFBBQ!'s Avatar
The proper way to do things is to buy a new prop valve. So you dont have to, but you should.
Old 07-06-2008, 02:35 PM
Banned
vannak_5415's Avatar
Default Re: (OMGWTFBBQ!)
just make sure when you do the conversion, make sure you bleed it or it will lock up in like a week, it happed to my brother 2 days ago. and he just used a 2000 si proportional valve and its work fine
Old 07-06-2008, 04:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! &raquo;</TD></TR><TR><TD CLASS="quote">The proper way to do things is to buy a new prop valve. So you dont have to, but you should. </TD></TR></TABLE>
Not really, as mentioned, the Si hatch (non-ABS) has the smaller 9.5" front brakes with rear 9.4" disks and a 3035 prop valve. This is the same as the Civics without the rear disks.
Old 07-06-2008, 04:22 PM
Seagull Management
94EG8's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Not really, as mentioned, the Si hatch (non-ABS) has the smaller 9.5" front brakes with rear 9.4" disks and a 3035 prop valve. This is the same as the Civics without the rear disks.</TD></TR></TABLE>
'94 - '95 Si's i believe got larger front brakes, can anyone confirm, also i've seen engine bay pics of Si hatches with the larger 15/16 master cylinder. what i guess i want to know is, is the larger master cylinder due to larger front rotors or ABS?
Old 07-06-2008, 04:33 PM
Default Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">
'94 - '95 Si's i believe got larger front brakes, can anyone confirm, also i've seen engine bay pics of Si hatches with the larger 15/16 master cylinder. what i guess i want to know is, is the larger master cylinder due to larger front rotors or ABS?</TD></TR></TABLE>
Only the 94 Si ABS had the 10.25" front brakes. Larger MC for larger front brakes (larger front calipers). Basically the 94 Si ABS has Integra brakes on.
Old 07-06-2008, 04:47 PM
Seagull Management
94EG8's Avatar
Thanks, that definately answered my question.
Old 07-06-2008, 05:31 PM
roycivic92's Avatar
i have the 40/40 prop valve,drums need less presure so im going to change it . i had to many close calls. when u brake hard the front tend to lock up quicker. my set up is gsr all around.
Old 07-06-2008, 05:33 PM
Default Re: (roycivic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 &raquo;</TD></TR><TR><TD CLASS="quote"> i have the 40/40 prop valve,drums need less presure so im going to change it . i had to many close calls. when u brake hard the front tend to lock up quicker. my set up is gsr all around.</TD></TR></TABLE>
When you go to a larger front setup, it is recommended you change the prop valve. When you just have the rear disk conversion with the 9.5" front, you don't need to.
Old 07-06-2008, 07:37 PM
damn thanks guys for all your answers. It will help a lot when I do my rear disk breaks!!!
rediye
05-09-2009 11:04 AM
ceezo70
13
02-11-2009 08:38 AM
slimjimdanny
03-21-2007 10:07 PM
EGhatched
10
03-31-2004 08:45 AM
arcsec
11-23-2002 11:55 PM
Quick Reply: do i Need a Proportion Valve of I want to upgrade from Drums breaks to Disk Breaks ??? Need Help
