It really must be my lucky day, first over heating problems, now the damn thing won't start...
Yeah, I just went outside to start my car and for God knows what reason, it won't start. I got 3 clicks from the starter, then nothing. Then I went to do it again, got the same 3 clicks and then nothing. The third time, I turned the key, and the car went entirely dead and now I have no power in the car. I tested the alternator the other day and it was good because I had the same problem. I have no clue what this car is doing, someone please help...
Re: It really must be my lucky day, first over heating problems, now the damn thing won't start... (
couple thing it could be have you tested your battery or make sure your have your battery connectors tight also wanna make sure that your batery cables are clean and no corosion down the line anywere. mine did the same thing was just ab loose cable.
Negative battery cable wiggled itself loose. I was so worried about the positive one, I didn't bother to check the negative one. Thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longshot »</TD></TR><TR><TD CLASS="quote">check engine grounds, check starter grounds</TD></TR></TABLE>
apparently we don't read. he got it. it was the negative terminal from the battery.
