brake fade problems
brake fade problems
this is a 94 civic ex non abs, rear disc conversion
new brake fluid
bled 3 times now
not loosing any fluid
so i swapped in rear disc with a 30/40 prop valve. bled the brakes. and was having problems when i was on a hill the brake pedal would start to fade and then i would pump it and it would hold pressure for a little longer.
so i swapped over to a early prelude mc that is 15/16 and im still having problems with the brake fade. in the next couple days im gonna get a brake bleeding machine and try that.
otherwise do you guys know why the brake pedal would be fading like this? what causes it usually? with a little pressure i can feel it fade almost to the floor
new brake fluid
bled 3 times now
* B A N N E D *
Re: brake fade problems (sohctodohc)
brake fade is when the pads, rotors and fluid heats up and doesnt slow you down like it should.
your problem just sounds like you have a leak, a line is expanding or one of your seals, probably in your mc is bad.
Re: brake fade problems (count me out)
might be the mc. but i cant imagine my old one goin bad and now the new one having a bad seal to.
when you put on a new mc do you have to bench bleed it??? cause i didnt.
also there is no leaks anywhere i have never once been low on fluid and the fluid in the system is brand new.
* B A N N E D *
you can bench bleed it on the car, but yeah, you will put air into your system without bleeding it before hooking up the lines.
* B A N N E D *
you dont cap them off when you bleed it. you need to get a bench bleed kit with comes with lines and nipples to screw into the mc line holes.
Jaydeep
06-25-2012 09:25 PM
JDMTEG98
Suspension & Brakes
07-10-2009 09:20 PM
dnt94civic
06-07-2002 05:04 AM
