broken trans mount need advice..
I'm looking to buy a civic with a b16 swap, but the bad is that the trans mount is broken. You can hear the motor mount rub againts the bolt it was held on to when you shift at high rpm. Is this an easy fix?
TIA
Modified by R-81 Coupe at 1:30 PM 7/8/2008
TIA
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: broken trans mount need advice.. (R-81 Coupe)
what part of the mount is broken? trans side? mount itself? chassis side? seriously, we need pics, or more info.
was the car Automatic ? that trans is sitting a little high most Honda transmissions have a good 1 1/2 or more in clearance this one does not. If it was you need a automatic to Manuel motor mount it lets the transmission hang lower and further away from the body.
Re: broken trans mount need advice.. (slvrcvc93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcvc93 »</TD></TR><TR><TD CLASS="quote">was the car Automatic ? that trans is sitting a little high most Honda transmissions have a good 1 1/2 or more in clearance this one does not. If it was you need a automatic to Manuel motor mount it lets the transmission hang lower and further away from the body. </TD></TR></TABLE>
yeah, it was an auto.
