P28 on b18c1
P28 on b18c1
Hey I have a GSR b18c1 swap in my '92 Eg HB.Im using a chipped p28 and I don't think Im getting good gas milage.As a guess I'd say I'm getting 15mpg.My car also spits out light blackishgray smoke.Should I change the ECU to see if I can get better gas milage.
Thanks
Thanks
Re: P28 on b18c1 (ChinoXdope)
Well black smoke indicates you're running rich - you could have the wrong fuel map burnt on.
Go get another chip from a company (plenty around here on H-T) - just a regular chip with a B18C1 basemap burnt onto it - pop it in, and see if there's a difference.
If there's no difference, then your problem is elsewhere, though I would just double check the contents of that chip - and a chip in and of itself isn't too much, I'd try that first.
EDIT:
Or if you can borrow a P72 to use, that's fine too, but I wouldn't bother buying one.
Also, if everything with the ECU is fine, change out ur primary O2 sensor.
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinoXdope »</TD></TR><TR><TD CLASS="quote">Hey I have a GSR b18c1 swap in my '92 Eg HB.Im using a chipped p28 and I don't think Im getting good gas milage.As a guess I'd say I'm getting 15mpg.My car also spits out light blackishgray smoke.Should I change the ECU to see if I can get better gas milage.
Thanks</TD></TR></TABLE>
A big question is, when do you start getting the smoke? at idle? 4k rpm? under heavy loads? WOT only? more info bro
i had the same thing, in my b16 hatch, i swapped out the ecu for a jdm p30 (del sol dohc vtec ecu) and i get good gas mileage even with a CEL. go with a p 30.
Re: P28 on b18c1 (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">
A big question is, when do you start getting the smoke? at idle? 4k rpm? under heavy loads? WOT only? more info bro</TD></TR></TABLE>
I heard you do chipping?..Is there anyway you can be able to get me a chip with B18C1 basemap burnt onto it?
I heard you do chipping?..Is there anyway you can be able to get me a chip with B18C1 basemap burnt onto it?</TD></TR></TABLE>
Yea, Your still going to be using the P28 w/o IAB's?
PM'd
PM'd
Well II have a P28 now thats chipped but my MPG is crappy,I was thinking of getting a P72 and chipping it,but Im still thinking on which one would help me better on gas.But as of now Im thinking about re-chipping my P28
sounds like you just need a stock p72 computer, which i have.
havent looked inside to see if i have chipped it yet, however its for sale.
if your concerns are gas MPG, you should get a p72 or have the IAB's installed onto your p28. stock maps w/ IAB's will get you good gas MPG again.
Dood just have someone on here, thats in your area of florida and get a good street tune spend the 200-250 bucks. That will help if not fix all of your problems. Not to mention you will make more power! That is unless you have another issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinoXdope »</TD></TR><TR><TD CLASS="quote">How much would you sell the P72 for? And if I wanted to keep the P28 how much would it cost to have the IAB's installed into my P28?..</TD></TR></TABLE>
p72 for 130$ + ship.
Adding IABs for 25 to a p28 only!
Check around in your area for a p72 first to save yourself shipping. IMO a p72 is gonna be your best bet for the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd »</TD></TR><TR><TD CLASS="quote">Dood just have someone on here, thats in your area of florida and get a good street tune spend the 200-250 bucks. That will help if not fix all of your problems. Not to mention you will make more power! That is unless you have another issue.</TD></TR></TABLE>
yea at least 250 and remember its a stock gsr, so the HP or even TQ improvments are NOT worth the money.
For some odd reason I like using my P28,but yea your right,I think I'm just gunna go buy a P72 and see if that helps.But since my P28 is chipped and I pop V-Tec at almost 5,000 rpm wouldn't the stock P72 change that unless I chipp it.
Modified by ChinoXdope at 12:41 AM 7/12/2008
yea, lets just try a chip then, email me your mailing info and i mail you back paypal caddy. Jimjones07@sbcglobal.net
JDMb18c1HATCH
08-20-2010 07:06 AM
wrxya33
06-26-2007 02:13 PM
